Old Mon 01 October 2012, 02:29
Quadro
Just call me: Anthony #77
South Australia
12/14 free machining mild steel
I have been ask to make a custom golf putter head out of 12/14 'high speed' free machining mild steel.
What is classed a 'high speed'?
Has anyone had any experiance with machining it?
Old Mon 01 October 2012, 03:48
I think its 706
Old Mon 01 October 2012, 06:39
http://www.ajmarshall.com/Manganese.htm
Looks like carbide mills will do it but no Rockwell hardness data to go on to be absolutely sure.
Old Mon 01 October 2012, 16:13
Allegheny
Just call me: Brian
Massachusetts
I could be wrong and you might be able to do this, but I wouldn't even think about trying it.
The surface cutting speed and chip load for steel is one, if not two orders of magnitude below what a router or spindle can commonly be set. A MM also has nowhere near the rigidity needed for machining metal - consider that a Bridgeport weighs in at 2,00-2,400# and it's top speed is around 1,000 rpm (which is almost never used).
If you decide to try this, I suggest you set everything on the slowest speed, with a feed rate as slow as possible (as in 0.001-0.005" per second - but only if you can get the spindle rpm to the 400 - 500 rpm range). Even then, I'd make sure you set up plenty of guarding with plexiglass as the bit will almost surely shatter.
Brian
Taxachusetts
Old Tue 02 October 2012, 02:42
Quadro
South Australia
Thanks for reply Brian,
I think the spindle will burn out at that rpm.
I'll put it down to a bad idea.
Thankyou once again.
Old Tue 02 October 2012, 12:00
First real question should be why the heck do you need a HSS golf putter
Old Tue 02 October 2012, 15:46
Quadro
South Australia
I don't know?
I have only 'played' golf once, 20 years ago it involved beer at each hole and golf buggies with a trailer full of beer to 'top up'. By the end of the game the Golf Club offered me a job to mow/slash the grass, double vision was not helping.
I was given this link to a steel putter thingy.
Old Tue 02 October 2012, 16:07
this guy made a cnc mill for that task, but his are made from brass
here is his site
http://www.deschampsputters.com/process.html
and thread on cnczone
http://www.cnczone.com/forums/vertic...ill_build.html
and video of machining
http://www.youtube.com/watch?v=9vWqH...layer_embedded
I am posting this as its very interesting and parts have a beautiful finish, you might learn something or even try machining brass on mechmate
p.s. don't know why I remember all this stuff but 2 years ago I got cnc crazy and read all interesting stuff on the cnczone
Old Tue 02 October 2012, 21:31
Always fancy copper head. some how it feels & sounded better than steel head.
Steel L profile tomasptacek Rails & Rollers 3 Wed 26 May 2010 08:37
Possible way to get recycled steel? bosox79 10. Base Table 8 Thu 05 February 2009 05:19
Machining polycarbonate ("Lexan") J.R. Hatcher Cutting various materials - bit selection, feeds, speeds 8 Sun 02 November 2008 22:26
Pre-finished steel rails from Standard Steel Specialty dmoore Rails & Rollers 0 Thu 01 May 2008 16:28
Machining of the rails jeff Archives 23 Wed 20 June 2007 07:43
