Old Fri 12 August 2016, 07:09
Jonazizbey
Just call me: Jonazizbey
Dubai
United Arab Emirates
Stepper Motor tuning Help, Please
Hello to All CNC masters.
I am Aziz from UAE. just recently i assembled my CNC plasma Cutter,
Started to Mach3 set up process, but couldnt manage motor tuning, almost 2 days trying to figure out but no result,
Checked all wiring, seems all OK.
But motors moution is noisy and not smooth. Unregular Sounds also,
https://www.youtube.com/channel/UCdg...WxDwnbXvBGjNzg
https://www.youtube.com/watch?v=YmG-6-vaL14
https://www.youtube.com/watch?v=eMOcU-Bip_Y
I could not archive higher speed than thi vedio, its a smoothest motor tuning pulse/revolution that I managed to set up.
Calling axes to home speed also not enough high, and
All motors are set up on 30 volts and 3.2 Ampere.
Pulse/ revolution is 1600 so 1 step is 0.225 degree.
If I set more smaller degree motor movement is getting more and more slow, even if it gets better smoother,
Motors are choosen as per advised by Mechmate plama plan.
This above vidoe is taken when all set up was done MAX CL Enabled mode .
If I remove that, after setting up, all of my motors are not working properly, drawing things incorrectly, even if i make calibration many times all of axes. losing steps. I changed pulse/ rev also to all of revolutions , But no result,
Is it must to remove click from MAX CL Enabled mode on Mach3 Config/ Pin and Port?
Please help if anyone has a similar experience,
Motor parameters
Nema 34 Stepper Motor 68mm 3.4Nm(481.5oz.in) 4A 34HS27-4004S
http://www.omc-stepperonline.com/nem...04s-p-129.html
Driver as suggested by seller.
http://www.omc-stepperonline.com/24-...42t-p-293.html
Old Sat 13 August 2016, 05:38
Welcome to the forum!!
I had a great response to this, but deleted it geeez !!!
What are your Mach Settings?
What voltage is your power supply?
I would think the NEMA23 driver is not a match for the NEMA34 motor.
And this should not be an issue, but I like the 640ozin size motor but the 400ozin range motors should work.
Old Sat 13 August 2016, 05:43
I set you up a build thread. You have to post us some pictures of your build !!
Nice looking machine from what I see in the videos.
You building a plasma table?
Need to get a MechMate logo on that one and get a serial number!!
Old Sat 13 August 2016, 06:04
Jonazizbey
Dubai
Hi Mike Thank you for your reply
I have read almost most of forums about MAX CL Enabled mode, i has to be unclicked
Im going to do motor tuning , axes calibration, today again one more time, let me try again,
by the evening i will upload photos and video, and plasma... file. details
For now Please tell me,
My motors are OK?
and driver suitable for above motor. Bipolar Stepper
More motor details are here
gear rack 25mm, for 1.5 mod, 15x15 mm rack.
Old Sat 13 August 2016, 06:06
Jonazizbey
Dubai
Please tell me how can I post? I cant upload a photo on site.
Old Sat 13 August 2016, 06:17
Jonazizbey
Dubai
[IMG]C:\Users\Computer\Desktop\pinion for aziz[/IMG]
Thank you very Much, Yeah I made it , from A - to Z, but still need to launch an see how this machine will work.
I will get licence and all other needy things. but I have been wondering with motor tuning,
What are your Mach Settings? -- Soon I will upload photos of my set up and even more videos,
I tried with 35 volts, and 2.8 amper 3.2 and 3.7 amperes,
Max allowed voltage is 50v and 4 ampers
Driver was suggested by seller for Nema 34,
I will try this motors first if not work, then i will order
Nema 34 CNC Stepper Motor 4.5Nm(637oz.in) 5.5A 34HS31-5504S
http://www.omc-stepperonline.com/nem...504s-p-72.html
or
Nema 34 CNC Stepper Motor 5Nm(708oz.in) 3.0A 34HS38-3008S
http://www.omc-stepperonline.com/nem...008s-p-32.html
Also wanted to ask,
may be i need to use Metal Head Metal Motor Plate for reducing vibration on cnc body and rack.
like this one http://www.mechmate.com/forums/showthread.php?t=3354
Old Sat 13 August 2016, 13:27
Jonazizbey
Dubai
Thank you, yes I have build one for myself just for hobby,
I will try to find out how to post with some photos.
So Today I did some advancement in motor tuning, here on the video all you can see,
https://www.youtube.com/watch?v=9kaB...ature=youtu.be
X axis -- Pin number --2, 3 640 pulse / revolution
Y axis - Pin number -- 4, 5 12800 pulse / revolution
Z axis - Pin number -- 5 ,6 25600 pulse / revolution
All set on 3.7 Am, 36 volts
45.000 HZ , unlicked MAX CL Enabled mode
Mach3 registered under someones name I downloaded in from internet, It is not like demo, functions are not disabled, I tested all are ok,
All axis are calibrated and when I move forward, backward, right let, up down all are OK, I think, X and Z axis are OK,
but Y axis has problem, He is not moving when you order something to pretend cutting, Its like not accepting order from Mach3 or from Computer or its not accepting all , I didn't understand really. need help to find out the problem
Y axis is also not feeling any Salved axes, I salved A axis for X axis, copied all motor tuning same, like Y axes, and from Configuration also, connected all, things, but no communication between slave and Y axis,
Old Sat 13 August 2016, 13:44
Jonazizbey
Dubai
This is G code I tried to check all axis movement
N5 (File Name = PLASMA TEST on Saturday, June 04, 2016)
N10 (Default Plasma Post)
N15 G91.1
N20 G0 Z-2.0000
N25 G0 X545.3094 Y82.5538
N30 G28.1 (Probe for Stock)
N35 G0 Z-8.0000
N40 M3(PLasma On)
N45 G4 P0.1000
N50 G1 X409.3094 Y200.5538 F2000.00
N55 X287.0926 Y92.8016
N60 X278.0887 Y84.8021
N65 X275.3094 Y82.5538
N70 X273.7802 Y85.5800
N75 X264.0594 Y259.3038
N80 X190.3321 Y263.0289
N85 X87.3094 Y267.5538
N90 X86.3094 Y268.5538
N95 X117.0608 Y302.7776
N100 X207.3094 Y403.5538
N105 X169.5572 Y445.7706
N110 X86.3094 Y539.5538
N115 X87.3094 Y540.5538
N120 X263.3094 Y548.5538
N125 X264.3094 Y549.5538
N130 X273.7802 Y722.5276
N135 X275.3094 Y725.5538
N140 X284.5262 Y717.8016
N145 X409.3094 Y607.5538
N150 X426.5262 Y622.3060
N155 X545.3094 Y726.5538
N160 X546.3094 Y725.5538
N165 X554.3094 Y549.5538
N170 X555.3094 Y548.5538
N175 X569.2785 Y548.0892
N180 X731.3094 Y540.5538
N185 X732.3094 Y539.5538
N190 X729.5494 Y536.3738
N195 X722.5572 Y528.3370
N200 X613.3094 Y403.5538
N205 X624.0616 Y391.3370
N210 X732.3094 Y268.5538
N215 X731.3094 Y267.5538
N220 X555.3094 Y259.5538
N225 X554.3094 Y258.5538
N230 X553.8356 Y239.5775
N235 X545.8639 Y83.5984
N240 X545.3094 Y82.5538
N245 G4P0.10
N250 M5 (Plasma Off)
N255 G0 Z-2.0000
N260 G0 X562.5031 Y422.9375
N265 G28.1 (Probe for Stock)
N270 G0 Z-8.0000
N275 M3(PLasma On)
N280 G4 P0.1000
N285 G2 I-152.2399 J0.0000
N290 G4P0.10
N295 M5 (Plasma Off)
N300 G0 Z8.0000
N305 M30
Old Sat 13 August 2016, 13:56
Jonazizbey
Dubai
mechmate photos
Finally I managed to upload
Old Sat 13 August 2016, 13:57
Jonazizbey
Dubai
there is attached My HTML plasma setting
Old Sat 13 August 2016, 14:07
Jonazizbey
Dubai
by the way. I also did this option to find out if Y axes motor is moving or no without load , I just removed it from where its fixed, then just put it on ground, connected Y plug and i check if it moves or not while pretending to cut. it not moving at all, but when it finish G code, i just pressed Go Zero for all axes, X and Z came to 0.00 position, and Y axes also started rotating as if it is coming to 0.00 position,
the problem is it is not moving when cutting G code but coming to home from the last coordination, if it was fixed on it place, it would have gone beyond limits. or 0.000.
Please guys advise me what problem might be this,
have anyone encountered similar situation
Old Sun 14 August 2016, 14:32
Jonazizbey
Dubai
Hi Mike This Aziz who built machmate cnc plasma recently. I uploaded some photos and videos,
By the way I found out the problem of setting, there is 3 drivers were not working, and this chines drivers is not accepting pulse or codes from Mach3, from 4 only one is accepting, So I had 3 other drivers brought before for nema 23 motor, I just connected them and tried again, very successful and very good. no vibration and smooth movement, all OK, Now,
I have seen and read your post http://www.mechmate.com/forums/showthread.php?t=3354
Please could you tell me from where you ordered
BPA01 Kit
1 Belt $8.00
1 Large Pulley $30.66
1 Small Pulley $14.92
2 Flanged Bearing FR8 Shielded $19.88
3 Flat Washer $0.79
2 1/4 20 x 1/2 bolts $0.25
2 1/4 Flat washers $0.25
2 1/4 Lock washer $0.25
1 3 Inch Drilled, Threaded and Milled Axle $25.00
I want to also built like this to reduce noisy more, and it looks more professional, also How to get the Metal Motor Plate bend part's drawing ?
I will update more photos and videos,
Old Sun 14 August 2016, 20:51
Can you tell us what 3 drivers you did finally use to get your issue resolved?
I sell this kit.
Old Sun 14 August 2016, 22:58
Jonazizbey
Dubai
Hi. Ok. I used DQ542MA Wantai Drivers. 18-50 volts. Max 4 amper. But I want to order other one because this drivers were bought for nema 23. 425oz.in motors. Motor's crancking noisy has almost gone after i use this driver.
What drivers do you advise me to get for Nema 34. With 481 oz.in ? I will post new video today.
how much do you sell that kit for belt drive?
And what does it include ?
I was thinking to build belt drive which increases speed. As my motors are 481 oz.in. i made a mistake. I was supposed to buy motor with 800 oz.in.
I dont know may be buying better driver will increase speed.
You can make for me belt drive which increases speed. Like ration 1:1.5
Old Mon 15 August 2016, 02:11
Breakout board you are using has optocouplers on step and dir outputs which are slow and are limiting your performance , and they serve no use because on the drives input you have also optocouplers. I suggest you to either modify the breakout board or use another one and you will see dramatic improvement in performance.
Modifying requires you to either solder wires before optocouplers or remove them and jumper from buffer chip to output screw connector
Old Mon 15 August 2016, 09:52
Jonazizbey
Dubai
Hi Danilo
Thank you for your advise, May be because of this optocouplers my old drivers didnt work properly. it was having a problem in reading mach3 signals, Sometime working sometime no, I will better remove them otherwise it will take much time to order and wait till it comes, I am attaching here bigger pictures of my cnc board, and some related data sheet i found,
Please tell me which legs needs to be connected after the removal it,
Old Mon 15 August 2016, 13:13
Jonazizbey
Dubai
I have uploaded some more videos of Accuracy and Step lose checking. i think this time drivers gave better result. I am also considering buying more stronger driver DQ860MA 2.8A~7.8A for Nema - 34 motors,
https://www.youtube.com/watch?v=yI-u...ature=youtu.be
https://www.youtube.com/watch?v=GjSlsPXKN6c
https://www.youtube.com/watch?v=y8h8...ature=youtu.be
Old Mon 15 August 2016, 15:31
First try to solder the wire before smd resistor 331 which goes to the input of optocoupler on pin 1 and go with the wire to the drive directly.
if that works correctly than if you want the use that board you should remove the optocoupler and the resistors on the output marked 102 (on your picture R34-R37) and jump from opto pin 1 to pin 4
Old Mon 15 August 2016, 15:35
Looking at the videos I hear the pinion rattle when the machine reverses direction, you really should install springs and allow the system to compensate for height difference between rail and rack,
right now you have lots of backlash
Old Tue 16 August 2016, 00:07
Jonazizbey
Dubai
Thanks Danilom for your advises, I will try to do that today.
Old Tue 16 August 2016, 09:48
Jonazizbey
Dubai
Danilom I tried but the result is same, however i have another one from old cnc machine, i may try that, also driver pulse/rev was set on 6400, i made it 3200 it is much faster now, i need to adjust rack also,its not laying in a same line, it may be giving rough noisy because of that, to completely reduce noisy i still need to assemble something like this photo, belt reduction
Old Wed 17 August 2016, 14:26
That board is ok I use the same ones
get the 4 wires from two terminals labeled PC 5v to the step and dir + on drives, pul/dir from board go to step dir - on drives and you will be good to go.
remember to connect USB power as it powers the 5V on the bob, 24Vdc is just for inputs and its regulated down to ~10V for the optos which accept NPN input from proxy sensors.
Old Sat 20 August 2016, 23:57
Jonazizbey
Dubai
Hi Master Guys need your advice, Please
Where should be zero for Plasma Z axis?
My CNC plasma Z axis moves within 100 mm length. MAx 0mm and Min -100mm
Initially I made Z axis home location is upper point Z zero, and it goes to torch metal plate below Zero, like it goes down -85 mm to detect material and probe.
But I am a bit confused After I watched videos on youtube , Guys are marking Z zero when its nearly torch metal cutting plate. So their Z axis never goes below Zero.
I have probe and THC, still doing set up for Sheetcam post processor and creating G code for Test Cut..
I would appreciate if you give me your valuable advises,
When I bought THC. I was given a M3 and M5 Macro files to change from Macros/Plasma folder on Mach3...
I have changed them, But now sure If I need to write any numbers there below on the fields marked ()
M3
DoButton (24) 'home for the command of Z'
While ismoving () 'wait until Z stops'
Wend
DoButton (10) 'Zero Z'
code ("g0z1.5") 'for the Z-axis cutting head upward so that an optimal range by section right (in this example is 1.5 mm) '
While ismoving ()
Sleep (1000)
Wend
ActivateSignal (OUTPUT1) 'opening plasma'
Sleep (600) 'wait 600ms'
DoButton (10)
StartTHC () 'THC control mode cutting head height'
DoButton (0) 'Run'
M5
M5 Code:
EndTHC () 'off mode THC cutting head height control'
DeActivateSignal (OUTPUT1) 'plasma initials'
code ("g0z10") 'Z-axis travel up to 10mm'
Old Sun 21 August 2016, 02:01
This macro is for using floating head switch as home , you cant have soft limits or another home in the upper position
For plasma I use probe input and probing G31, look for a script on machsupport forum
This M3 of your is very wrong, putting G0 1.5 in m3 will limit you in a way that if you cut thicker material you have to change the script ... and I can's see a way to get to the pierce height?
You can have custom macro Mxxx and it should only probe down find the switch get the offset zero out the Z on the plate and thats it. Sheetcam postprocessor puts out the pierce height and fires the M3 then gets to the cut height.
Also for plasma go in to ports and pins and spindle setup set all the delays for spinup to 0.
Old Sun 21 August 2016, 02:40
Jonazizbey
Dubai
Hi Danilom Thank you
I have removed Z axis, So no more limit , home there. later i will do
I have also probe, pin 11 is activated, only need correct macro for it. i have not activated output signal or relay for plasma on, as plasma get on in a different way.
The guy who sold THC is not replying yet as today is weekend, but I am trying to to somehow,
and I found a macro from this site, http://proma-elektronika.com/index.p...kcja-materialu
and tried this macro http://proma-elektronika.pl/download/m300.m1s
and copied it and changed with macro number m3 on plasma folder after that tried one of my drawing g code which i prepared with sheet cam yesterday,
Uploaded video is here https://www.youtube.com/watch?v=X6l6...ature=youtu.be
I think its working but still need to adjust some of parameters,
It is 2 times coming to detect material.
How can I remove unnecessary part from above macro?
So that it comes one time to detect the material. and starts cutting,
The THC I bought is very very similar to the above site, but its from Vietnam
this one http://robot3t.com/products/mechaniz...mpact-thc3t-02
I guess THC starts acting after detection of material.
Please if this video and macro are still wrong, share me your, let me see how its written, may be i can write mine according to yours.
Old Sun 21 August 2016, 04:57
Because you are using referencing and its not set up right thats why its coming down two times.
You need a correct post from Sheetcam, to use with probing floating head.
I can send you the post I use and a macro for touch off, floating head Z offset can be entered in macro or in DRO made on mach screen.
For thc in mach to work you need to have plasma screen loaded and in the middle is a button THC ... its THC ENABLE.... beside it its THC ENABLE LED. Without it enabled it won't listen to THC UP / DOWN
Old Sun 21 August 2016, 04:59
This is how I do it.
https://www.youtube.com/watch?v=5xldgVGG1-k
Had a hard drive sudden death, send me your email and I'll get you the files soon as I find them.
Old Sun 21 August 2016, 05:27
Jonazizbey
Dubai
my email is [email protected] I have made some changes now I will upload videos , i am taking it
Old Sun 21 August 2016, 05:58
Jonazizbey
Dubai
I watched your videos, works perfectly.
what post processor should I use for to coordinate with Macro and probing floating head?
I activated already THC with pin,12,13 up down. wiring also has been done, just disconnected THC from power, no useless to connect without plasma, but , soon I am going to bring one, as i finish this macro and metal detection set up
Old Sun 21 August 2016, 07:07
Email sent.
When you get this going if you have time put the whole process of setup here so everybody else can learn. I got no time right now for a complete how to.
beside UP / DOWN you need ARC OK ... or THC OK in input pins, Mach wont move if THC is active and there is no THC OK (ARC OK) signal
Need help with jog speed in Mach3 motor tuning !!! rival Troubleshooting 45 Sat 03 September 2011 06:03
Gecko / Motor Tuning sailfl 701. Motor Drives 9 Tue 06 April 2010 13:13
