Old Sat 08 December 2012, 08:45
skypoke
Just call me: Chuck
Port Aransas
Buy, rent or borrow skate
I have one of the more original Mechmates, with a cutting area of 6' X 20. My rails are less than optimal, we built it before the grinding skate was put into common use. I'd like to touch up those rails to a more accurate grind. If anyone has a skate they aren't using I'd like to get my hands on it. Happy to pay for the accommodation. Unfortunately I never was assigned a serial number but I believe it was around build # 6.
I'm happy to report that my Mech has been bulletproof, even surviving a 300 mile move in one piece on a large boat trailer. Thanks, Chuck Pearson
Old Sat 08 December 2012, 09:30
Hey Chuck,
Good to hear you are still around. I thought you had sold your Mechmate when you were moving a while back? Im sure Mike has a set of grinder plates he would sell you to make your own skate. Drop him a pm.
Mike, Chuck should get a serial number now for sure!
Old Sat 08 December 2012, 17:41
skypoke
Just call me: Chuck
Port Aransas
Hey Chuck,
I briefly entertained the thought of selling it but thought better of it. I ended up moving it away from the coast into another shop, away from the threat of hurricanes. I got some looks towing this substantial machine through the middle of Houston but the boat trailer transport worked out like it was built for it.
Quite frankly, I can't see any inaccuracies induced by my less than perfect rail grind, it's just the compulsive side of me that says "hey, that could be better." I probably should just do as I remember Gerald recommending, some draw filing.
Nice to see the forum active and machines proliferating.
Chuck
6001 Bearings for Skate - Surplus Zouave The Market Place 4 Fri 09 July 2010 10:31
Some alternatives to Bosch grinders for skate dmoore Rails & Rollers 17 Mon 22 March 2010 04:47
What are the size of the 8 bearings on the skate? lumberjack_jeff Rails & Rollers 1 Tue 16 June 2009 19:44
Used skate chuck252 Rails & Rollers 6 Wed 10 December 2008 21:02
V-Rail profiling device - an alternative skate design Atifeh Rails & Rollers 9 Fri 25 January 2008 10:12
