Old Mon 18 June 2012, 12:09
raw Particle board cutting
I need to cut a lot of 19mm Particle board, its raw, without melamine top.
Really its just packaging grade of board. Order is to cut about 20-30 sheets/month. There is around 35 pieces on one board so its a lot of cut path.
Anyone has in mind some router bit to use? Edge quality is of no concern as it will be covered with fabric later. I need something rough that will just rip it apart
had this in mind:
http://www.cmtutensili.com/show_items.asp?pars=RC~196~2 around 35eur for 8mm , think that it will be strong enough to cut it in one pass.
Old Mon 18 June 2012, 21:04
digger
Just call me: Milosh #113
Toronto
You may try with compression bit.
Old Tue 19 June 2012, 02:02
Compression bits are working for me when I have to cut sheet material.
Old Tue 19 June 2012, 03:23
digger:
samo ti zezaj
I said its a low grade particle board with lot of impurities, and edge does not have to be perfect or good.
So that is why I have not considered compression bit (price difference).
What to use to cut Melamine Board? Daya Cutting various materials - bit selection, feeds, speeds 17 Tue 13 March 2012 23:08
Control Board Help Please paul60 70. Control Systems 8 Wed 07 October 2009 23:52
What is the purpose of a spoil board or bleeder board? j_wizard 10. Base Table 1 Sun 09 August 2009 18:00
Cutting Foam Core Board jhiggins7 Cutting various materials - bit selection, feeds, speeds 3 Fri 17 April 2009 14:26
cnc4pc board help smreish 70. Control Systems 1 Wed 23 April 2008 06:22
