Old Sun 28 August 2011, 13:40
Rusty Nuts
Just call me: Gary #86
Valley Grande, AL
Selecting resistors for Gecko drive
I'm using Gecko 203V and the resistor listed for 4.5 amp motors is 1/4 Watt 84.6K. I checked with Radio Shack and I could only find 1/4 Watt 100k and 1/4 Watt 47k. Will I be able to use one of these sizes or will I need to order some off of the internet?
Gary
Old Sun 28 August 2011, 15:43
Three options for you to consider: Buy one of their kits, like the 500 resistor kit 271-312 for $10, which contains 5 82k resistors - close enough.
The other option is that for resistances in series, you add them; for resistances in parallel, you average them. So, as an example, wiring four 22k in series would get you 88K; or wiring 100k and 47k in parallel would get you 147 / 2 = 73k. Add 10k in series to that and you hit 83k.
Third option is to buy potentiometers like 271-092, dial in the resistance you want using a meter when it is out of the circuit. Although this sounds attractive, I'd stay away from it; low quality pots can vary and degrade over time, and you actually don't want to have it too easy to vary the current since a mistake could destroy something.
I suggest you buy the kit; it's short money, and you'll have a bunch of resistors around to allow you to make current adjustments.
Old Sun 28 August 2011, 16:47
Gary,
If you want to wait for snail mail, I can mail you some on tuesday.
A small assortment even.
Old Mon 29 August 2011, 03:02
Brad, your averaging of resistors in parallel is faulty logic. Haven't got time now to set it right, but this had to be nipped in bud. Maybe someone else can step in while I get some work done?
Old Mon 29 August 2011, 03:03
Resistors in parallel always give you less ohms than the lowest one in the set......
Old Mon 29 August 2011, 03:13
Use the formula of 1/R = 1/R1 + 1/R2 + 1/R3 to compute resistance in parallel.
A 1000 ohm resistor in parallel with a 100 ohm resistor gives 90.9090 ohms of resistance.
1/1000 = 0.001 ohm
1/100 = 0.01 ohm
0.001 + 0.01 = 0.011
1/0.011 = 90.9090 ohms
Old Mon 29 August 2011, 06:27
Ah, that's right. Thanks for the corrections.
Old Mon 29 August 2011, 06:33
Buy a UIM ROBOT driver...amps are set on potentiometer...no resistors needed
Old Mon 29 August 2011, 08:43
Thanks Mike!
Old Mon 29 August 2011, 20:49
I just love math.....it keeps me honest.
Using the Gecko G540 drive a MechMate stefanv 701. Motor Drives 42 Sat 07 May 2011 04:45
Alternatives to Gecko Drive? liaoh75 70. Control Systems 4 Sun 09 May 2010 12:03
Resistors for G504 and wiring for PK296A2A-SG7.2 motors (unipolar) jehayes 701. Motor Drives 7 Sun 15 November 2009 19:16
Resistors martin77pl 702. Power Supplies 11 Sun 21 June 2009 22:22
How do i wire this which gecko drive to use eloid Archives 1 Mon 05 March 2007 06:07
