Old Thu 28 July 2011, 07:11
mrakoplas
Just call me: martin
praha
Czech Republic
Starting Mechmate in Czech Republic
Hi,
My name is Martin and I live in Czech Republic.
I have the plans for Mechmate for few years now, but I did not have a time to start until now. I'd built in meantime a small CNC from MDF. The working size of my Mechmate is going to be 2070 x 2850 mm.I already outsourced the laser cutting and bending, bought Geckos and other electronics. Now I am about to order the material for the table. I am a bit confused if I should buy circular or rectangular tubing. In the drawings are used pipes, but I saw many people to use rect. tubing. Any advice? Thanks
Old Thu 28 July 2011, 08:00
pipes are preffered but some of us feel more comfortable dealing with rectangular tubes (cutting joining). So use pipes. As I understand they are stiffer than same size rectangular.
Old Thu 28 July 2011, 21:37
Welcome. The base is very flexible as to how you build it. Tube is sometimes easier and cheaper to aquire. But square will work. Looking forward to your build.
Old Thu 04 August 2011, 06:05
mrakoplas
praha
Czech Republic
Thank you very much for your comments.
Old Wed 10 August 2011, 05:41
mrakoplas
praha
Czech Republic
I am now reconsidering the size on my mechmate. The length will be definitely 2800 mm, but the width could be either 2070 mm which is standard for MDF or I could do it just 1250 mm, which standard for most other materials, such as plywood. Is there a significant structural loss and increased building difficulty comparing 2070 to 1250 mm? Thanks
Old Wed 10 August 2011, 06:18
I made mine and friends for width of full board, the difference in cost is so small you would not notice it. And it is well worth the little extra effort if you can spare the extra width in your workshop.
There are a lot cnc machines around that can do 1250 width but very few that can do 2050 like mine, keep that in mind when thinking of size.
Also plywood sometimes comes in 1525x1525 sizes (the quality ones here) so it is always advantage to have a full width and use material properly without large offcuts.
Gantry tubes on mine are 3mm thick and my friends are 4mm, go for the 4mm tube wall if you can. It seems to me that he is having a little bit less vibration. And the extra mass is always welcome. Also you can tap in 4mm and leave out the strip inside tube.
Old Wed 10 August 2011, 07:27
One other consideration is the operating convenience; you can reach almost every point on a 1250mm wide machine from one side or the other. At 2070mm, you will need to climb on top more often, depending on what type of work you do. Think through how you are going to do your material hold downs.
Old Wed 10 August 2011, 07:59
mrakoplas
praha
Czech Republic
Thanks a lot for your quick comments. I am not afraid of the climbing on the table, and Danilom has a good point that is more difficult to find a cnc machine bigger than 1250. Therefore, I think I will do the 2050, the only thing I am afraid is that it will be much more difficult to reach a good precision of the machine during the build.
The starting points for building your own MechMate - selecting table size, etc. Gerald_D General - MM Build 154 Thu 31 December 2015 08:23
Starting up in AZ Mojo Construction started, but not cutting yet 43 Wed 15 January 2014 07:46
Starting Up in Atlanta ga. kimbrell Introduce yourself and start planning 11 Mon 09 May 2011 22:42
One more MechMate starting - North Carolina, USA Bernhard Construction started, but not cutting yet 5 Fri 28 December 2007 16:11
Starting MechMate build planning - a broad question on performance specs. dneisler Archives 3 Sun 22 April 2007 14:56
