Old Sat 26 February 2011, 08:30
isladelobos
Just call me: Ros
Canary Islands
Spain
Searching a good TAP WRENCH
Hi.
Im searching a good tap wrench for my shop, in my search i see the STARRET from USA.
STARRETT NO.91-(ABCD) TAP WRENCH
I need a recomendation for this tool and taps, and good online site for purchase.
And this is the Starret tap system the best for tape?
Thanks.
Old Sat 26 February 2011, 10:03
I have used expensive tap wrenches and cheap tap wrenches and they were all okay. For the MM you will only need one size, about 200mm. I have more sizes, but they are going rusty because they are never used. What can you buy in C.I. ?
Old Sun 27 February 2011, 02:21
Jan de Ruyter
Just call me: Jan
Pretoria
Use a carpenter's brace. It easily holds the square side of the tap in the chuck, you can apply enough pressure on the brace's end while turning it with the other hand and it is much easier to keep perpendicular with the workpiece.
For me, it works better than a tap wrench.
Old Sun 27 February 2011, 02:30
isladelobos
Just call me: Ros
Canary Islands
Spain
Thanks Gerald.
One tape wrench for M1 to M12 is 200mm.
M12 hole is about 10mm
Here is difficult adquire industrial material, we are a holidays place and no main island.
About the tap's , im thinking in Yamawa or Dormer? or some other good quality.
Yeah Jan.
Very good idea, i go test this.
Regards.
Old Sun 27 February 2011, 02:44
Jan de Ruyter
Just call me: Jan
Pretoria
Tip: if a tap breaks, pour some nitric acid into the hole, it will loosen the tap. The acid will attack the high carbon tap steel. You can also knock it out with a hammer and a punch as the tap is very brittle.
Better still, for every 2nd revolution, turn it back half a turn to break the swarf.
Old Sun 27 February 2011, 10:24
I am sure there are some companies in Puerto del Rosario harbour area who repair boat/ship equipment. They should be able to tell you where to get some basic tools.
Las Palmas has enough industry. Example www.repnaval.com
Old Mon 28 February 2011, 06:09
Red_boards
Just call me: Red #91
Nice info, thanks Jan. (After I tore up a drill removing a broken tap). I'll know next time.
Old Wed 08 June 2011, 13:02
jehayes
Just call me: Joe #53
Whidbey Island, Washington
Smile
Great idea! Wish I had thought of it!
searching for buying a mechmate ebarotte The Market Place 3 Sun 30 January 2011 05:57
MechMateWiki.com - free to a good home Delamination Miscellaneous / General / Whatever / Catchall 1 Sun 19 September 2010 08:49
Searching parts isladelobos The Market Place 0 Sun 06 December 2009 17:34
