Old Tue 22 March 2011, 23:49
tnarch
Just call me: Tuan
Milwaukee WI
Gecko 201X Adjust Screw
What is the function of the Adjust screw at the top of the drive? I searched the manual many times, and can't fine any reference.
Old Wed 23 March 2011, 06:03
Manual only states this:
RESTORING FACTORY DEFAULTS
To restore the G201X to the factory settings set the trimpot to the 11 o’clock position and set SW1-SW10 to “ON”.
On other models like G540 the trimpot is used for midband resonance tuning.
Old Wed 23 March 2011, 10:11
This is from the 203V manual. I think it is for low speed tuning.
ADJUST: This trimpot adjusts the motor for the smoothest possible low-speed operation. Set the motor speed to about 1/2
revolution per second and then turn the trimpot until a distinct null is noted in the motor’s vibration. This will result in the most
even microstep placement for a given motor and power supply voltage. The default setting for this trimpot is at ½ -turn and the
setting for your motor will be within +/- ¼-turn of the default setting.
3d Mold divot issue - SOLVED - Loose screw holding pinion gear salewis Troubleshooting 41 Tue 23 November 2010 12:36
Grinding flat spots on shaft for set screw seating kanankeban Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 8 Fri 02 July 2010 01:33
Gecko / Motor Tuning sailfl 701. Motor Drives 9 Tue 06 April 2010 13:13
Screw threads - inch & millimeter Gerald D Golden Resources 1 Mon 09 March 2009 01:54
gecko 210 WOODCHUCKMAN 701. Motor Drives 3 Sat 21 February 2009 14:13
