Old Fri 07 May 2010, 00:55
Rook3
Just call me: Russ
Bemidji, MN
Smallest project size for a full size MM?
Just wondering what the smallest project size can be done with a "full" size Mechmate, one with an appx. 4x8' work area.
Can you do real small stuff, like custom etching dog tags for example as well as doing full size signs?
I have a list of potential projects in a wide variety of sizes.
Russ
Old Fri 07 May 2010, 01:17
The machine has got the resolution (especially if you add reduction drives), it just depends on how small your cutting tool is.
Old Fri 07 May 2010, 02:27
Browse the The Show Room and see some small stuff like this one:
http://www.mechmate.com/forums/showthread.php?t=2163 (the rule there is showing centimeters, not inches)
Old Fri 07 May 2010, 14:26
Rook3
Just call me: Russ
Bemidji, MN
I just ran across the build thread of Jayson in Australia showing some small projects he's done.
Great! really looking forward to starting my build now that I know it can pretty much do everything I require.
Thanks everyone!
Old Fri 07 May 2010, 15:26
Small things from my side on 2400 x 1200 mm table...
http://www.mechmate.com/forums/showt...&postcount=212
Old Sun 09 May 2010, 06:27
Jayson
Just call me: Jayson #18
Horsham
Yep, small should be no problem depending on what it is you are doing. My belt reductions are only 3.2:1 so if you use 7.2:1 and forgo some speed you could get it even finer than I have. Having said that, I have not seen the need for more accuracy.
Good luck.
Jayson
Rack Metric Size 1.5 liaoh75 Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 26 Sun 27 February 2011 04:39
What are the size of the 8 bearings on the skate? lumberjack_jeff Rails & Rollers 1 Tue 16 June 2009 19:44
Need to clear something up on Table size Medemt General - MM Build 5 Tue 24 March 2009 07:22
maximum tabel size ? pafnc 10. Base Table 4 Sat 07 June 2008 11:29
Just curious shop size David Smith Archives 3 Tue 24 April 2007 16:32
