Old Thu 08 April 2010, 03:25
15mgtar
Just call me: 15mgtar
anaheim
Nema 42 Motor Size Question
I have bought the wrong motor size which are nema 42 size with 19mm shaft. Can you guys tell me which rack and pinion size to buy? I will be running mach3 in metric.
Old Thu 08 April 2010, 04:05
Ouch!
No worries, IMHO, you can still use Mod. 1 gear & rack, 24 teeth will be too small but 30teeth is big enough to cater 19mm shaft.
You need to mod the laser profile parts as well, motor mounting plates & carrier plates... Just a few that I cna think of.
Old Thu 08 April 2010, 04:22
15mgtar
anaheim
Thank you Ken, where do you buy your rack from?
Old Thu 08 April 2010, 04:38
Deitech in Hong Kong. they are cheap but with some quality issue, which is still well worth my money.
Old Thu 08 April 2010, 06:12
15mgtar, you have several things to check/solve before proceeding with those motors.
- Shaft size / pinion size; if you'll be happy with the final gear ratio, what the torque will be.
- Redesign of the motor plates, also clearances of the motor positions, changes in the springs.
- Drivers capable of running those motors; power (voltage/amperage) to run those drivers, speeds of the motors, etc.
Bigger doesn't always work out -> think installing a tractor motor in a motorcycle.
You might find it easier and less expensive in the long run to return or E-Bay those motors and get another set.
Old Thu 08 April 2010, 06:18
I second Brad's advise. Unless you are competent with the necessary design alteration on your own.
Old Thu 08 April 2010, 09:15
Size 42 motors may be difficult to drive if you use Gecko stepper drivers. Big motors may require expensive electronics. Big motors often run much slower than smaller motors.
I agree with Brad and Ken. Rather than redesigning the machine, it would be easier to sell the motors and get some size 34 motors that better match the design.
Old Thu 08 April 2010, 19:58
Ditto on the sell and rebuy of Nema 34 motors.
Old Thu 08 April 2010, 22:14
Why a stepper motor should not be too big . . . .
Old Fri 09 April 2010, 03:03
15mgtar
anaheim
I already have the motors and the drivers . the drivers runs on 110-220vac. Selling them would be a greater lost, I'm very low on money so I just have to stick with them.
I really don't know about shaft's size/pinion size (19mm/30???maybe 34 minimal?) and final gear ration so if you guys would kindly guide me through.
Old Fri 09 April 2010, 03:39
I recon not selling them will be a ever bigger lost.
Sell them & start over again.
does anyone offer a kit with 7:1 reduction with nema 34 motors . . . . . toad Motors & their mountings 25 Thu 28 January 2010 01:08
Mr Lasercut&bend has his own machine drawing pictures! #42 - Birmingham, AL jbmclain MechMates already cutting 25 Mon 14 December 2009 10:27
True Torque of a Servo motor for comparison to a Stepper motor, when used in a router Mcyoda Motors & their mountings 3 Tue 19 August 2008 01:50
What does a stepper motor look like inside? (geared Oriental Motor) Gerald D Motors & their mountings 0 Sat 16 August 2008 09:29
Do the Oriental Motor gearheads fit onto all NEMA stepper motors? alain26 Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 7 Wed 02 July 2008 09:57
