Old Thu 25 March 2010, 16:07
PEU
Just call me: Pablo
Buenos Aires
A different hold down approach
Today I visited a customer of the CNC machines I sell, besides this machine he has a medium size router he uses to cut airplane models.
He uses 2mm boards, and his main problem when he started was keeping the board flat, so he came with a solution, take a look:
This is the view from the top, the hole in the middle is where the spindle passes thru this gizmo, the side tube its for the vacuum attachment, and the holes on the sides are guiding holes, thru them ride two guides that are attached to the spindle. You can leave this head floating, meaning that it touches the material to be cut, or it can be fixed at some height.
this is the view from the bottom, the radial holes are there to prevent the vacuum lifting the board and to catch the produced debris, the delrin center is raised a little so only the plastic touches the wooden board to be cut
another view of the bottom side
and a straight view from the top.
He also designed a version 2 of this gizmo, inspired mostly by how the sewing machines hold the clothes where they need to be, he does not built it because version one works dandy, here are the drawings:
What do you guys think?
Pablo
Old Thu 25 March 2010, 21:32
What a beauty!
Love the 1st version, simplicity at its best! Easy to construct & simple to use. Especially admire the use of the radial holes to relief excess suction pover while providing a vacuum curtain around the cutting point.
AND it floats too!
Wonder if making the chamber out of acrylic would be practical, or maybe glass for its any scratch property.
I just decided to go with this design for my build.... later...
Like Ver 2 is a bit, but more tricky to build.
Thanks for sharing.
Old Fri 26 March 2010, 00:08
I cannot see the pictures on this idea...all other pictures show up OK.
Normally this happens from work with the firewalls and rubbish there, but from home I never had this problem. Anybody else that cannot see the pictures, then I can start to look for my problem.
Old Fri 26 March 2010, 00:16
No pictures visible from 2 different PC locations/types.
Old Fri 26 March 2010, 00:19
www.peu.net has crashed
Old Fri 26 March 2010, 06:40
PEU
Just call me: Pablo
Buenos Aires
its up now!, sorry guys, just in case it crashes again, here are the photos at an alternate location: http://www.dropbox.com/gallery/36245...ddown?h=cc2944 in the same order presented here.
New hold-down product iqchallenged The Market Place 16 Tue 23 February 2010 12:09
Looking for parts for vacuum hold down system liaoh75 General - MM Build 2 Wed 10 February 2010 11:12
An approach to extending Z-Axis. bradyaero 40. Z-Slide 86 Tue 18 August 2009 09:12
Vacuum Hold Down Systems fabrica 10. Base Table 32 Sun 25 January 2009 13:45
All acrylic gate valve for the vacuum hold down paco 10. Base Table 7 Wed 26 December 2007 09:58
