Old Thu 20 October 2011, 03:15
Tonys
Just call me: Tony
Suffolk
Backlash
I have the PK296AE SG7.2 on my machine with mod1 rack and 30tooth pinion. I broached the pinions to take a key way and used two set screws at 90 deg to fix to the shaft. With everything switched on i.e. motors under holding torque I can get ,measured with a dial indicator, up to 1.1 mm movement on the Y car by physically rocking back and forth-about (.5 mm in both directions.)
I wondered if any one has done tests on backlash, and if this is an acceptable level?
I am just starting with the Mechmate so learning curve very steep.
Old Thu 20 October 2011, 04:43
1.1mm is way too much! Can you show a pic of where the dial gauge is located and where you apply the 0.5mm rocking ?
Old Thu 20 October 2011, 10:54
Tonys
Just call me: Tony
Suffolk
Sorry about quality but here are pictures of the set up I used. The DI shows 0.5mm movement each way with a single handed push and shove! If you think this is an appropriate way to test I will test the other axis. I am not engineer so any guidance or advice would be appreciated.
Old Thu 20 October 2011, 10:56
Tonys
Just call me: Tony
Suffolk
Sorry fogot the pics
Old Thu 20 October 2011, 11:04
Tony, 1.1 or 0.5mm for that setup is something very big and you should see the cause of it easily with the naked eye (without a dial gauge). Are you sure that you are not measuring 0.11 and 0.05mm) a factor 10 less?
Old Thu 20 October 2011, 11:07
I dont see spring on the Z motor, do you have it on other motors? if you just pushed the motors to the rack and bolted then you could experience some backlash.
Old Thu 20 October 2011, 12:21
Tonys
Just call me: Tony
Suffolk
Gerald, you are absolutely right. I could say age and poor eye sight are to blame but more likely a non engineer trying to use proper engineering tools! Thanks
Danilon, yes springs on all motors Gerald got it in one.
Old Thu 20 October 2011, 13:46
Tony, I have been there.....more than once.
Can backlash give a cumulative error? Gerald D Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 43 Sun 31 January 2010 13:08
Backlash compensation lumberjack_jeff Troubleshooting 10 Sat 14 November 2009 08:30
Gearbox Backlash Is this to be expected? Cutter99 Motors & their mountings 4 Mon 15 June 2009 12:07
Backlash in the rack & pinion system eloid Archives 15 Thu 06 March 2008 07:29
Zero backlash gears vadeem Motors & their mountings 6 Fri 24 November 2006 09:55
