Old Tue 19 January 2010, 10:11
stueve22
Just call me: Travis
Missouri
Planning to build in the next 3 months or so. - Missouri, USA
I have been reading the forum for weeks now and have a question. I read the whole motor selection thread twice, but have a question about bending or breaking the rules. I already have a 3 axis controller and motors that i setup for converting a seig x2 direct drive with ball screws. The motors are 425 oz inch from Keling with a 3/8 shaft, NEMA 23 but 100mm long. http://www.kelinginc.net/KL23H286-20-08B.pdf If i go with a 4:1 trans and make 23 to 34 adapter plates would i be able to get by at some level of performance for a while before spending more money on a bigger drives motors etc... The drives i have are http://www.kelinginc.net/KL-4030.pdf with a 24v power supply that came as a kit with the motors and power supply a few years ago. Could I possibly get a higher voltage power supply with the same drives? specs say up to 50v.
Old Wed 20 January 2010, 06:22
I believe the 23 Motors are to small for the MM. You should just seel the 23 motors and buy some 34 motors.
Old Wed 20 January 2010, 13:48
Welcome Travis, you should be looking at Nema 34 size motors for the MM.
Planning a new build in Edam - The Netherlands Polder48 Introduce yourself and start planning 9 Sun 02 August 2009 06:56
Newbie looking to build first CNC - WI, USA jpietrowiak Introduce yourself and start planning 4 Tue 07 July 2009 10:35
Going for it! 5'x10' build. - El Paso, USA robertmonroe Construction started, but not cutting yet 12 Wed 18 February 2009 15:58
A few questions (pre-build / planning) rdfl General - MM Build 16 Wed 04 February 2009 11:55
Starting MechMate build planning - a broad question on performance specs. dneisler Archives 3 Sun 22 April 2007 14:56
