Old Mon 12 October 2009, 06:51
isladelobos
Just call me: Ros
Canary Islands
Spain
Speed Test
The intention of this thread is adquire data matching their speed test to see who can make mechmate in a specified MDF thicknes and hardness most useds.
I put this data, but you can add more to complete the test data
DATA:
Link to your machine thread:--:
Motor type:------------------:
Gear Ratio:-------------------:
Number of teeth:-------------:
Drill power:-------------------:
Drill rpm:---------------------:
Max free IPM:----------------:
Max cutting IPM:-------------:
Max free mm/s:---------------:
Max cutting mm/s:------------:
You can add vídeos or images from your cutting qualities.
Old Tue 13 October 2009, 05:07
isladelobos
Just call me: Ros
Canary Islands
Spain
Note:
For see the Max free velocity, we can test with a ballpen in the Z axis (we see lost steps)
I think this is the First data needed when a mechmate is finished and tested.
Max. speed of the MechMate - moving, cutting, jogging . . . . sprayhead General - MM Build 31 Fri 19 February 2010 06:28
What type of cutter to use and what feeding speed to cut aluminium hennie Cutting various materials - bit selection, feeds, speeds 1 Fri 24 July 2009 10:24
test test buibui Test Area for this forum 0 Mon 20 April 2009 01:08
Router speed control coogrrr 50. Toolheads 18 Sat 23 February 2008 04:05
Test DocTanner Test Area for this forum 0 Mon 15 January 2007 12:27
