Old Wed 18 November 2009, 05:03
Coil Inductance measurement, is this normal?
I bought these 86HS9801 specs
It says the coils has 4.1mH
I measured the inductance between the wires & the results as follows
Coil A, 3.64mH, 3.67mH, 3.71mH, 3.67mH (Red-Yellow)
Coil B, 3.61mH, 3.46mH, 3.53mH, 3.80mH (Orange-White)
Coil C, 3.62mH, 3.42mH, 3.56mH, 3.77mH (Brown-Green)
Coil D, 3.65mH, 3.71mH, 3.72mH, 3.66mH (Blue-Black)
Are they consider normal?
I'm using 48Vac tranny should give about 65~66Vdc,
Consider these,
32*sqrt(3.4) = 59V (lowest measured value)
32* sqrt(3.8) =62V (highest measured value)
32*sqrt(4.1) = 65V (original based on maker's spec)
The motors will run 5~7 V higher then recommended voltage.
Will I be in any sort of problems?
Thanks in advance.
Ken
Old Wed 18 November 2009, 05:33
I don't think you will have a problem . . .
If your motors run a little bit too hot, then reduce the current setting on the drive.
Old Wed 18 November 2009, 07:38
aniljangra
Just call me: Anil #44
Delhi
Ken
I'll trust the documented Inductance value as I think the inductance may vary with frequency (the freq used by you measuring instrument may be different).
Old Wed 18 November 2009, 07:47
Anil, I'm using a DMM to measure, not sure what frequency the use though...
Thanks again. will have to remember keep a close monitoring on the heated motors.
I am also concern that the values varies greatly between coils & motors. Is that normal?
Old Wed 18 November 2009, 09:04
aniljangra
Delhi
I'm not an expert on this but i think Inductance is measured at 1Khz, rotor locked position. Anyway as Gerald said it doesn't matter here, just keep an eye and reduce voltage if motors seems overheating.
Old Wed 18 November 2009, 09:53
The biggest variance is between the 3.42mH and 3.80mH measured values. The average value between those two is 3.61mH with a variance of 0.19mH to either side. That is only 5% . . . . . which I think is darn good!
Old Thu 19 November 2009, 01:31
OK, inspired by gerald, I took a quick stats analysis with spreadsheet, I get standard deviation of 0.08 & a median of 3.65, that is +/-2.2%. I can ask any better then that.
This is the wiring diagram I received, want to be sure that I'm doing the correct thing.
For half coil, use
1) coil A(red-yellow) & coil B(white-orange)?
2) it really doesn't matter as long as we take half of each phase?
Old Thu 19 November 2009, 01:44
For half coil, use
Quite correct on both points.
Old Thu 19 November 2009, 02:36
Thank you for you reply.
Ken
In need of a little advise from the experts...series or half-coil wiring? jeffa Motors & their mountings 7 Mon 17 August 2009 12:57
Why Mariss uses 32 X SQRT(Inductance) to calculate voltage of power supply Richards 702. Power Supplies 5 Wed 08 April 2009 21:50
Contactor does nothing when powered? - Correct terminals for coil Doug_Ford Troubleshooting 11 Sun 11 November 2007 19:23
