Old Fri 11 December 2009, 06:36
PEU
Just call me: Pablo
Buenos Aires
Shop Air Cleaner - DIY
While chatting with folks at another forum, one told me about this simple air cleaner for the shop, specially good for MDF particles: http://www.fountainclan.com/wood/Air%20Cleaner.html
Gerald: I searched before posting, if its a dupe please delete
Old Sat 12 December 2009, 04:57
Besser
Just call me: Besser
Vic
Nice process post.
As a secondary shop filtering system it would be nice to have cleaned air. A little noisy though.
Probably easier catching the particles at the source. Though you need the air speed velocity to be enough to snare the ejected particles.
Set up the bag outside and the finer stuff can keep your neighbors cleaner in steady employment, your garden composted and a clean shop!
Old Sat 12 December 2009, 11:53
Besser,
Only problem for those of us with a hard winter is keeping the heat in the garage. Hard enough to keep it heated in Canada, to just throw it outside with the dust!
Old Sat 12 December 2009, 21:19
I added a better filter to the dust collector. With that I don't think you need a separate air filter for a small shop.
Old Sun 28 March 2010, 00:57
Zouave
Just call me: Eric #115
Sacramento, CA
Actually, I'd say that any sized shop should have one of these in it. We really don't realize how bad the air is in the shops that we work in until you have one of these set up and running. It makes a tremendous difference. Especially if you're like me, and like to take high pressure air to most of the work surfaces, and anywhere on the tools where dust collects that you can't get with either a hand broom or a vac... I do that at the end of the day and then leave the shop because there is so much junk in the air, but at least most of it settles out on the ground instead of in my machines, and then I can sweep it in the morning. We put one of these in the shop I used to work at, and it made a HUGE difference. I'm definitely going to either get one of these (The JDS 750er would be quite nice) or make my own like the build listed. Its TOTALLY worth the effort and money.
Old Thu 07 February 2013, 22:30
Lord Maximus
Just call me: Alex
Tucson (AZ)
I use a scratch built vacuum system that sucks all dust out of the shop and into a collection bin located outside, and I also have a 6500CFM cooler going that "pressurizes" the shop and helps push everything out. It's a highly effective system and I don't have to worry about particles that would go right through a bag or filter.
Moving the beast around the shop - wheels, etc. Greg J 10. Base Table 12 Mon 22 November 2010 06:53
Air Drill Jay Waters 50. Toolheads 41 Sun 14 November 2010 19:09
AIR in AIR out - analysing the air flow at the collection point Besser 55. Dust Management 17 Wed 16 December 2009 07:44
Air-powered routers? kooskoek 50. Toolheads 7 Wed 19 August 2009 17:46
Just curious shop size David Smith Archives 3 Tue 24 April 2007 16:32
