Closed Thread
Old Sun 14 June 2009, 10:57
lumberjack_jeff
Just call me: Jeff #31
Montesano, WA
Search functionality
Would it be possible to turn off the minimum string length function in search?
I find myself often searching for things in which the three-character strings is the most important term, such as VHB or DXF.
Old Sun 14 June 2009, 11:50
jeffh
Just call me: Jeff #21
Bellingham WA
Hey Jeff!
I had the same thought but I found that if I put quotes around the smaller words the search works.
Been watching your build and it looks like it's going great!
Later,
-The other Washington Jeff (with a wood table)
Old Mon 15 June 2009, 13:44
I agree; the search facility of this forum stinks! Have been meaning to find something better.
You guys that hang around on other forums, do you know of a vBulletin forum with a nice search facility?
Old Mon 15 June 2009, 14:06
I have found the same problem on most of the forums and even the VBulletin ones. I like the idea of using quotes.
It would be great if they came up with a different way of searching.
Old Mon 15 June 2009, 14:34
Actually, that's an old, old problem in electronic searching. Many people use short words in their searchings that should not normally be indexed. We used to call those "stopwords" in library systems. For example, "a", "and", "the", "in", etc.
If you search them by default, your result sets end up unusably large, and relevancy numbers get thrown off. The article with the most " a " in it tends to win in any search including " a ".
A more modern choice is to rely on the searcher (that's you) to give a hint to the search engine that you really want to search on a short word. It eliminates built-in stopwords, which used to cause other problems in certain search domains. Hence the search working when enclosed in quotes.
Old Mon 15 June 2009, 20:58
lumberjack_jeff
Montesano, WA
I eventually used google;
e.g.
download dxf site:mechmate.com
Closed Thread
