Old Sat 25 July 2020, 12:30
dbinokc
Just call me: DB #118
Oklahoma
Cheap 1500W Fiber Lasers on Ebay
I recently noticed some $1000 1500W fiber lasers heads for sale on ebay recently. It is just the head and does not include the power supply. I am curious if anyone has investigated what it would take to get one running.
It does not include a power supply, so at a minimum that would be needed. I am sure what else would be required.
Old Wed 29 July 2020, 15:24
I installed couple of fiber laser systems, not knowing what have you seen the head is least of expense, the source and fiber with connector to the head is much more. Also Head can be with autofocus or without, for enhanced piercing. That needs dedicated control that also has capacitive control of head height. After that you need a large chiller to cool down the laser source, much smaller than co2 but still very much needed.
To control the system at cutting speeds above 5m/min and rapids above 60m/min you need a fast system dedicated for laser cutting. Cypcut does the job.
Old Wed 29 July 2020, 15:38
dbinokc
Oklahoma
An example of one the one I saw on ebay is at
https://www.ebay.com/itm/Raytools-BT...4AAOSwgtpezUyy
It looks like the head should be able to mount directly on the z-axis.
Cutting Carbon Fiber in the CNC pinhocareca Cutting various materials - bit selection, feeds, speeds 5 Tue 13 March 2012 19:25
Look Ma! no lasers (3d scanning via webcam) PEU General - MM Build 24 Sun 29 May 2011 01:32
HSD spindles currently for sale on eBay jeffa The Market Place 18 Tue 17 August 2010 17:20
Geckos on Ebay 275 for 3! stefanv Archives 0 Fri 08 February 2008 10:59
Anyone has any idea if this drive is something I could use off eBay? Kim Mortensen Archives 1 Thu 08 February 2007 18:40
