Old Thu 14 July 2022, 17:15
greuterfarms
Just call me: Tim
Tn
The easy part is done in Tennessee!
I started this build a few months ago. It's not a MechMate per say, but I incorporated a lot of MechMate concepts into the build. I used materials I had laying around the farm for the framing and just engineered the build around those materials. The machine capacity is 5'x20' with a 5'x10' vertical table on one side. I will be using this cnc to surface and tongue and groove oak slabs (60"x96"x2-1/2") that I'm using for flooring in my log cabin. I will also be machining two sets of heavy timber stair stringers (4"x14"x18') and all the cabinets for the cabin. I bought a 7.5KW Air Cooled Spindle and VFD, 4 STEPPERONLINE Nema34 12Nm Closed Loop Stepper Servo Motor Hybrid Driver Kit, 4 Nema 34 Planetary Gearbox Speed Reducer Gear Head 5:1 and a DDCS-EXPERT+MPG offline controller. Now the hard part of figuring out how to run the controller begins.
Fire, how easy it is to start one! smreish 55. Dust Management 8 Sun 10 October 2010 21:22
Easy way to get a cyclone if you..... Regnar 55. Dust Management 4 Fri 24 September 2010 22:23
Easy Torroidal Transformer Mitch_1 702. Power Supplies 2 Sat 07 November 2009 06:52
Timing pulleys made easy stcnc The Market Place 0 Mon 08 September 2008 16:02
