Old Sun 13 December 2009, 20:11
Travish
Just call me: Travis #75
Wa
Newest number ripping up hardwood #75 - Arlington, WA
Hello all,
I have been a member since 2006 and was around for the 1st release of the drawings and I remember watching Fabrica build one of the 1st ones. I remember knowing that one day, I was going to build this beast. Well that day has finally come. I have been in and out of the forum saving notes for the day I would finally have the opportunity to build.
I want to thank Gerald, Mike, Heath, Doug, and Sean and many others for being patient with those who are learning. This forum great to be apart of and is very different from others on the net.
The Specs on my build-
50” x 105” cutting area
4- OM PK296A2A-SG7.2 motors
30-tooth spur gear
4- Gecko-203v
PMDX-122 with standoffs for stacking a 2nd board to daisy chain
800w 70v power supply
Wiring full coil
Control panel 18”x24”x8” Enclosure
5hp Colombo Spindle
Table will be made out of I-beam, channel, and square tubing.
I’m designing the table to allow me to add growth to the machine later down the road. Table is drawn on center line due to the extra room for a second spindle. There is also room for an A-axis off the ends of the table. As you’ll notice, there is room for 3 more gecko’s in the control box when called for.
I wanted to tackle the hard part 1st. For me that was the control box. I knew if I got motors turning, I could relax and enjoy then the rest of the build.
The project started making a lot more sense when I started getting components in. Then things started to really happen.
After checking and re-checking, I flipped the switch and got power in all the right places, then hit the on button and after about 3 seconds I knew I was good. Green lights in all the right places!
Next step was to get those motors hooked up and Mach3 configured.
Things went well here as well. Motors are turning and tuned! I couldn’t imagine trying to do this on the machine! Take Gerald’s advice and do it on the bench table.
Shuttle Pro 2 is configured and up and running as well.
My steel list is off to the supplier so I can have it all here for the X-mas break.
I'll be clearing the garage to make room for the steel this week.
Old Sun 13 December 2009, 21:26
Hi Travis,
Nice to know your back and will finally making your wish, a beast of your own. Well prepared to
I too was waiting for a loooong time before start, so I can truly relate with your enthusiasm to achieve it.
Well, looking forward to see your steps too and WISHING you all the best on your build !
Amicalement, Robert
Old Sun 13 December 2009, 22:58
Well done Travis!
Old Mon 14 December 2009, 02:49
Travis
Your controller box looks great. Looks like you picked a large box which makes it easier to work in if you have to plus it gives you more room while you are wiring it.
Look forward to seeing you table.
Old Mon 14 December 2009, 03:42
Travis,
Well done! Looks like you will be making wood dust in no time.
Large control panel is a very clever decision, like real estate, one can never have enough space.
Old Mon 14 December 2009, 04:45
Travis, looking at your table pics above, realise that the table top is typically not centered between the main beams. ie. the table is not symmetrical in the x-direction. See 10 10 300 W and notes at the bottom about centerlines.
Old Mon 14 December 2009, 10:29
Travish
Wa
Thanks for keeping an eye out Gerald. Perhaps you may have forgotten about our discussion about the table on centerline here- http://www.mechmate.com/forums/showthread.php?t=2185 . I extended the rail length by 4.0" on each end rather than adding 8.0" to one end. Your right, it's not typical per the standard 3.9" offsett in the drawing.
Old Mon 14 December 2009, 11:35
Oh, it was you! (I can't keep track of who's who anymore )
Old Tue 15 December 2009, 15:55
jehayes
Just call me: Joe #53
Whidbey Island, Washington
Travis: Your control box looks good. Any chance we can get together at some point so I can get pointers on setting mine up? I have all the pieces but, frankly, am a little lost in the wiring stage. Thanks Joe
Old Tue 15 December 2009, 16:01
Travish
Wa
Gerald- Ha! Lol, no worries! your doing great!
Joe! Sure, come on by anytime. Give me a ring.
My steel is coming this friday, so I'll be busy over the break! Looking good so far.
Cheers,
Travis
Old Sun 03 January 2010, 22:00
Travish
Wa
Latest progress- Table is Standing
Here are some pictures of my progress over the x-mas break. I met my goal of having the table standing before I have to go back to work. Welding for the 1st time went well. I recycled and old speaker box and made a little welding cart with some wheels. After the steal came in, I cut everything to length with a chop saw and bandsaw. I spent two full days just cutting! Then another 2 days drilling and prepping for weld. Then the fun part came of putting it all together. I used a digital level which made life easy. The whole table went together well. I'm very pleased to have it standing finally! this week I will be disasembling the main rails to do some more drilling for the table supports and etc.
Cheers,
Travis
Old Sun 03 January 2010, 23:26
Originally Posted by Travish View Post
. . . Welding for the 1st time went well. . . .
Those welds look good. Great job!
Old Sun 03 January 2010, 23:37
buibui
Just call me: John #34
Seattle
BEAUTIFUL job Travis!
Old Mon 04 January 2010, 00:39
Claudiu
Just call me: Claus #43
Arad
Romania
Nice work....when I see this, it makes me want to start another build!
Old Mon 04 January 2010, 06:57
Beautiful work & nice progress…. I like this I-beam thing
Thanks for sharing too you build steps !
Amicalement, Robert
Old Mon 04 January 2010, 09:32
Looking Good Travis!
Old Mon 04 January 2010, 14:01
jehayes
Well done Travis! Glad to see the progress. And thanks again for your help over the holiday break. Joe
Old Mon 04 January 2010, 21:17
Travis,
Nice "W" shape beam. Welds - pretty. Really, your 1st time welding!
I will have to say, you have the "mass" part of the table down pat. How are you going to flip that monster! LOL
Old Tue 05 January 2010, 09:27
Travish
Wa
Thanks all for the comments! Yeah, I'm really having a blast putting it all together. As far as welding goes, I practiced 1st on a few flat plates in all the different positions to see what works and etc, did some reading and off I went. My plan was to start from the ground up and learn control, and hopefully the gantry and Y car will go smoothly.
I'm very pleased with the solidness of the table. Yeah the table has to come apart to flip it over for sure. I have some more drilling to do on the main beams for the table supports anyways, so it was a nice break finally do some welding after all the drilling and cutting.
Old Wed 24 March 2010, 21:13
Travish
Wa
Update- Y car Welded and Frame is Rolling
Hi Guys, I have been caught up with various things lately and am way behind on sharing my progress. Here are some pics that are past due. I should be starting the rails here shortly with my new "Super Skate" I made. I did a test pc on a short pc, and it is sweet to use. It is fully adjustable. The skates 4.0" 10.0" plate is slotted so it allows for a quick set and alignment of the grinding disk to the rail, then it's locked down and ready to go. The height adjustment rollers allow for a .105" drop when the pins are rotated 180 degrees. This making it a quick and easy visual. When the pins are pointed up it's ready to go, and when the pins are down, I'm done grinding.
I also got the Y Car welded as well. I machined a pair of plates so that it was square and tapped holes in the ends so that I could bolt it up and keep things square and paralell.
Old Wed 24 March 2010, 21:22
Great skate setup. Nice Y car pics. Nice welds and cool bolt together base
Old Wed 24 March 2010, 22:06
Travish
Wa
Thanks Mike!
One thing I forgot to add was the Castor wheels are removable as well. I just unbolt and the whole braket comes off. Since I had the castors and extra material laying around I decided to use what I had. So once it's in place I lower the table feet and level the table, and remove the wheels if I feel I want to. The table glides with little effort.
Old Wed 24 March 2010, 22:18
Travis, it looks like you you missed the fact that you have to offset the table surface (and its cross supports) towards the "home" end of the main X beams, because the router does not sit in the center of the y-car.
Old Wed 24 March 2010, 22:21
Oops, forgot the 14 December discussion .......again!
Old Thu 25 March 2010, 09:22
Travis I think the skate adjustment is a good design. Let us know how it grinds?
http://www.mechmate.com/forums/showt...0&postcount=66
Old Thu 25 March 2010, 09:47
Travish
Wa
Hi J.R.,
Yes, I'll agree that having the adjustment on board makes it too easy to use.
I have had limited use with it but have ground a few test cuts with it on some 1/4" plate and the skate grinds really well and is quick and easy to use. I have eccentric bushings on the front rollers and I machined a 16mm hex on it to be able to hold it while I tighten the thru bolt down to the plate. The rear rollers are fixed and the bearing pins sit in a precision c'bore to keep them from moving on the plate. All adjustments can be made while the skate is still on the rail which should make grinding go smoothly. I'm curious to see how it rolls on the hot rolled angle iron. Using the larger wheels should help it roll smoother. I'll keep you posted on the results.
Old Thu 25 March 2010, 12:48
jehayes
Travis: That is the most beautiful skate I have ever seen! Wow! I should have waited until you were finished with it and then borrowed it.
Nice job. Looks like you are getting close.
Joe
Old Fri 26 March 2010, 07:36
SumBum
Just call me: Jay (Bum)
PA
I think you could rent that skate out to members. Looks nice.
Old Tue 06 April 2010, 09:38
imakechairs
Just call me: Rob
Zebulon
Professional Job all the way!
I live near the shop bot place in Durham, been there to see their stuff, what you built is 10 times heavier
i just wonder what was the reason for bolting table parts together rather than just solid welding everything? would it not be a more solid unit if all joints were welded?
and what size steel you used?
Old Tue 06 April 2010, 10:03
Travish
Wa
Yes, making the Bolt together was for my needs only. I wanted something I could easily transport and move with my own hands to shop space as I grow. I needed something heavy and solid that would resist and moving and skewing if I had a rough load with the boards or a heavy piece of timber. It also needed to handle moving the table around in the garage or even the driveway as I am always changing the work layout depending on what tools I'm using to utilize space. This design is not for everyone. There is a lot of added time and materials to the table, but I am very happy with how it is coming along.
I got the Rails cut down 1.15 tall and holes drilled in the rails and is ready for grinding. Hopefully the rain stops here in Washington so I can get outside to grind some rail action.
Had a good day on the girl today! #45 - Melbourne, Aus rnixon MechMates already cutting 63 Mon 16 May 2011 15:54
Number 47 for sale - Macon MS blakekoehn The Market Place 3 Fri 15 October 2010 12:53
Communion cup holders from hardwood J.R. Hatcher The Show Room 18 Tue 10 March 2009 12:59
Introduction - Arlington, Washington State duluthboats Construction started, but not cutting yet 5 Wed 12 September 2007 04:41
