Old Fri 10 April 2009, 05:21
gorantec
Just call me: gorantec #59
bitola
Macedonia
Need help with rack dimensions :( - Bitola, Macedonia
sorry if is stupud to ask but im very newbie in this
i have here one suplier and making racks 60 sm long ok its not problem i will connect them but suplier ask me how much tooth did i need on 60 sm long racks so please let me know how much tooth will need ?
i was searching on the forum but nothing find and theat why i ask
Old Fri 10 April 2009, 07:11
gorantec
bitola
Macedonia
Ok if you dont understand me i was thinking how much tooth per 60 sm rail
Old Fri 10 April 2009, 08:04
Will your supplier also make the round (circle) gears that will run on the rack?
I ask that question because the round gears must be matched to the rack.
We normally use a "Module 1" rack in a metric country. For 60 centimeter there will be 190.986 teeth.
Old Fri 10 April 2009, 08:07
gorantec
bitola
Macedonia
yes suplier will also make gears
Thanks for your answer
Old Fri 10 April 2009, 08:19
If your gears are direct on the motor shafts (with no gearboxes), then your gear diameter should be 24 millimeter (at the middle of the teeth) and it will have a quantity of 24 teeth.
IF you do have gearboxes on your motor, then you can increase to 36 millimeter average diameter and quantity 36 teeth.
