Old Fri 01 February 2013, 05:16
carcan
Just call me: Carlo
Camparada
Italy
New Z-Slide or Prefab Rail Ideas!
Instead of using a plate, that is difficult to grind, why we can use two "classic" rails ?
Old Fri 01 February 2013, 07:50
Actually, the slide plate is super easy to grind.
If you plan on using a ground method as in your second picture, you just buy a 36" length of 100mm x 7mm Cold roll steel plate, then profile like the regular rails.
Then, cut to length on each end so you cut off the run off area of the skate profile.
Without checking the spider plate, I don't think you have enough clearance between the 45 deg bend in the spider to accommodate that extra width the angle profile adds.
I did this grind method 3 times - once for #5 with regular steel and the suggested tool steel on #28 & #58 - it was super fast with 36 grit paper.
Plus, doing in your second picture you may run the possibility of "less-than-parallel" slide from point to point based on you assembly method.
Just thoughts,
Old Fri 01 February 2013, 20:02
I agree that the "current" slide isn't rigid enough. BUT when looking at it as a whole, i.e. compact, weight & difficulties to fabricate. It is the best compromise... so far.
IMHO, The "New" design works too. The "less-than-parallel" can be corrected with some shims using the Fish line + filler gauge. The point to consider is whether do you really wanna go through the hassle?
Also, unless you use thinner & smaller angle iron, I don't see any benefit in weight saving.
If you are too lazy to hand grind, just get is on a milling machine.
Nevertheless, it is still a good attempt to improve on the current design.
Old Fri 26 April 2013, 10:11
litemover
Just call me: Chris
Auckland
New Zealand
Has anyone seen the makerslide design? This was interesting to say the least, very similar to the mechmate slide, cheap, and perhaps it could be incorporated into the mechmate somehow. It is a custom extrusion with rails for about $60 for 6'.
BTW, I think the mechmate slide is very cool, and griding the plate is easy.
http://www.kickstarter.com/projects/...bearing-system
http://makerslide.com
Old Fri 26 April 2013, 13:48
Having seen the amount of wear on a mild steel slide, and upgrading to tool steel for the z-axis, an aluminium slide will simply not give enough life.
Old Fri 26 April 2013, 16:19
jasoncarter
Just call me: Jason #82
Arkansas
Those sort of extrusions need steel raceways to be very useful.
Example:
http://www.pbclinear.de/pbclinear/pd...rospekt_A4.pdf
Old Fri 26 April 2013, 20:03
litemover
Just call me: Chris
Auckland
New Zealand
That's fantastic looking stuff Jason.
I'm sure it does wear much faster than steel but the extrusion from makerslide's targeted price is at $3 per foot.
Old Fri 26 April 2013, 22:19
Extrusion is cheaper, but do you really enjoy replace the worn AL extrusion every now & than? I would rather waste my time doing other unproductive activities...
Old Sat 27 April 2013, 03:52
carcan
Just call me: Carlo
Camparada
Italy
My idea is to have a system that you can build with the L steel grinded with the "skate". Also you can adjust the parallelism simply with very thin washers.
If you want to change the "nature" of the Z-slide probabiy the best solution is a pair of HIWIN rails.
Old Sat 27 April 2013, 06:32
Jason Marsha
Just call me: Jason
B'Town
Barbados
My problem with the makerslide extrusion is the protrusion of the running surface past the side of the extrusion. It looks somewhat weak may bend under pressure from the bearings.
Old Sun 28 April 2013, 00:54
Jason, bear in mind that they are talking plastic wheels . . . . . don't think they will bend the extrusion.
Old Sun 28 April 2013, 01:02
This thread is about the Z-slide. But if someone wants to do a useful extrusion for the other long rails, all we need is this:
The hard insert is readily available from a couple of suppliers, including Rick at Superior Bearings. Any old glue would hold the hard part in place.
If someone does want to go this route and borrow the idea from here, please give us credit by sizing the profile so that it fits within the MechMate dimensions
Old Sun 28 April 2013, 05:33
Our aluminum supplier will do the extrusion but we'd have to commit to 1500-2000 lbs/year. That's a whole lot of rail.
Old Wed 01 May 2013, 06:36
Jason Marsha
Just call me: Jason
B'Town
Barbados
I did not realize the design used plastic wheels for the makerslide design. Will the plastic be as rigid, compared to metal bearings when taking cutting forces into account.
The design will certainly save fabrication time but It won't not allow the Mechmate to cut to its full potential.
I like that design Gerald, a drop-in and glue.
Jason
Old Wed 01 May 2013, 07:24
Looking at Gerald's drawing above, I wonder if that could be cut from appropriate sized aluminum C channel on a table saw. The channel may need to be oversized to get the required thickness in the fillet.
First pass, with web against fence, trim one leg to height.
Second pass, trim the other leg.
Third pass(es), web up, dado the first leg
Fourth pass(es), dado the other leg.
Fifth pass, web down, split into two finished Ls.
Sixth pass, if needed, trim the larger L if they weren't equal.
Old Wed 01 May 2013, 08:01
just an idea? off the shelf components
...then use the epoxy method?
Or maybe just structural adhesive for the entire assembly?
Old Sat 04 May 2013, 17:40
Percy
Just call me: Percy
Fort Walton Beach Florida
I have worked with Iowa Aluminum who will make extrusion dies and do 500 pound runs with no setup charges. Runs down to 350 pounds can be done for a $200 setup charge. Don Wityshyn was my point of contact.
Old Thu 06 June 2013, 01:08
danhamm
Just call me: Dan
Williams Lake B.C. Canada
I don't know if this design will work on a mechmate, but cheap and easy to build, the one in picture is using bishop wisecarvers v-roller guides, the one I built is using rollon
v-roller guides, the diff being the rails and rollers on both are hardened steel but the body on rollon is steel also, I double trucked my z-axis as I have and adjustable gantry from 6 inches to 16 for timber carving.
Shop Security Ideas Regnar General - MM Build 5 Wed 27 October 2010 17:13
Ideas & Experiments with different rail styles Arthur Ransom Rails & Rollers 38 Fri 21 December 2007 15:25
Mamba logo ideas smreish Archives 18 Mon 03 December 2007 23:00
New Ideas and less Banging your Head - South Africa GARTH LEE Introduce yourself and start planning 1 Wed 21 February 2007 02:26
