Old Sat 26 January 2008, 16:22
Glitches in cut paths (rounded corners) - Using the Constant Velocity mode of Mach
It does cut, here's proof. Got tired of looking a file, this one comes with mach3.
Old Sun 27 January 2008, 09:06
JR, that "o" in Artsoft, is there a glitch at the 3-o'clock position, on the inner curve? Any signs of machine resonance and rough cutting, particularly on those slow curves in the word "Mach 3"?
Old Sun 27 January 2008, 11:20
1. No glitch. It's the point where it raises and lowers each Z move, I corrected some be extending the X & Y travel. It's rounding the vertical corners, there is a setting in Mach that fixes that just can't remember where, but I'll find it.
2. Not much, it will easily pass my scrutiny test.
3. Remember I didn't setup this file Art did. That was the second thing I changed (to Z.25) the first was the feed rate from F1.3 to F35. I've got to assume the file was setup for a milling machine and Alu.
Old Mon 28 January 2008, 06:22
Found it. It's called CV setting (Constant Velocity). When used it tends to round corners a bit. Seems like I had to run the lathe with it turned off .
