Old Sun 19 October 2008, 16:59
lunaj76
Just call me: Justin #24
Littleton, (Colorado)
Motors won't turn after the setting up - PMDX-122 jumpers incorrect
We are not getting any movement.
Please, will the voice of experience help!
Will post pics of mach screen shots shortly.
Old Sun 19 October 2008, 17:20
lunaj76
Mach settings
Mach screen shots.
Old Sun 19 October 2008, 18:40
Justin,
In the Motor Outputs tab, the "Dir Low Active" should be checked green.
I'll check for other things.
Greg
Old Mon 20 October 2008, 00:07
Havn't checked your Mach screens because I am rusty on that, but the following may help . . . .
Have you moved jumper JP1 on the PMDX to the lower GND side for the G203's?
Are any green LED's changing on the PMDX when you try and make the motors go forwards and backwards? (The LEDs nearest the DIR pins. ie pin2 on J1) should be "on" for one direction only). The STEP LED will blink too fast to see with the eye.
Old Mon 20 October 2008, 07:54
Greolt
Just call me: Greg
Victoria
Have you checked to see that your port address is correct?
Mach defaults to 0x378 but that is not always correct.
Check it in device manager. If not sure what that is then watch the Mach setup videos.
Greg
Old Mon 20 October 2008, 08:33
lunaj76
Thanks for the input we will check all these things and report back.
Old Tue 21 October 2008, 18:51
Have you checked to make sure all of your wires have continuity. You can touch the heads of the terminal screws at both ends of the wires with the probes of a multi-meter. I usually set the dial so that it beeps when I have continuity.
Old Wed 22 October 2008, 09:35
lunaj76
Thanks Doug, we will try that also. Can't get to it till this weekend, what a bummer.
Old Fri 24 October 2008, 10:53
lunaj76
Motor turns with different computer
We made the suggested changes (THANKS GUYS) but still no movement. So we installed mach on different computer and were able to get the motor to turn in one direction very slowly. My guess is that the printer port on the first computer is not strong enough. Can't wait to hook up the big power!
Old Thu 30 October 2008, 10:22
lunaj76
Video of one motor turning.
Check out the smoothness of the motor, can't get over it. Most of our problems in getting the motor to turn came from not having the jumper pins on the PMDX 122 in the right spot. Remember, there are more than just 1.
http://picasaweb.google.com/Tadeo.Luna/MechmateProgress
Old Thu 30 October 2008, 13:40
Hi Justin
Glad to hear that you have your motors turning smoothly now. How are your jumpers different from this post?
Old Thu 30 October 2008, 20:23
lunaj76
Gerald
My mistake was only moving JP1 down and not moving any of the other pins. We now have it just like your post. Did any one watch the Video?
Old Thu 30 October 2008, 21:37
gmessler
Just call me: Greg #15
Chicago IL
Great pics Justin.
Couldn't find any video though.
Old Fri 31 October 2008, 05:20
Justin I watched the video it's picture 41 of 49
