Old Fri 07 September 2012, 11:43
viz
Just call me: viz
Kaunas
Lithuania
Mach3 X axis with 2 motors set as slave
Hello,
I need some help, i have 2 motors for x axis. In mach3, one motor is set to X axis and second in A axis.
In mach3 i set Config->Slave Axis on X Axis i set slaved axis to A axis.
Now then i press left button both motors axis rotating the same side, but if i press right button both motors axis rotating to different sides ? Can't find answer to this problem.
Thank you for help !
Old Fri 07 September 2012, 12:36
Are you sure that each motor will turn forwards and backwards? Maybe you are seeing the one motor only go in one direction? Maybe it does not change direction because there is a broken wire, or there is an incorrect setting?
Old Fri 07 September 2012, 17:46
it looks like you did not correctly wire the step and dir signals or set them properly in mach3 config pins, in those cases you can see that kind of behavior. disengage the motors and you should find one that is spinning in only one direction so check that motors setup.
Old Fri 07 September 2012, 21:49
You might also has a loose parallel port connection.
Old Sat 08 September 2012, 04:48
viz
Just call me: viz
Kaunas
Lithuania
Thank you for help, i changed LPT cable to new one.
Also set in mach3 options showed in screenshot
Old Sat 08 September 2012, 05:10
viz
Just call me: viz
Kaunas
Lithuania
Also in X Axis we can uncheck "Step Low Active" and the motors still rotating to the same side.
Old Sat 08 September 2012, 09:41
Depending on the Breakout board and the drives, all step signals should be checked or unchecked, so they all react in same fashion.
check step/dir wiring to the drives.
Also depending on the drives they might be configured for CW/ CCW input rather than Step/Dir this might be the most obvious reason as you are feeding the step signal into only one direction input. In leadshine drives there is a jumper inside or a dip switch setting to change this to the step/dir logic for the two inputs
Old Sat 08 September 2012, 09:58
viz
Just call me: viz
Kaunas
Lithuania
Posted the screenshot but forgot to tell that now everything is working the problem was in LPT cable. Now my both motors work perfect and rotating to the same side. Thank you for quick answers.
How many motors use mechmate in the long axis albertoslayer Motors & their mountings 11 Tue 09 March 2010 11:44
The setup of 2 motors on 1 axis cnc'tje 60. Wiring & Cable Management 2 Sun 07 March 2010 11:38
Setting A-axis terminal as X2-axis in EMC2 KenC CNC motion control software 2 Wed 27 January 2010 06:40
Rotary axis (4th Axis) or Indexer software smreish Graphics & CAD 0 Tue 28 July 2009 07:02
Mach3 flaw for slaved gantry motors Gerald D CNC motion control software 8 Fri 10 July 2009 03:50
