Go Back   MechMate CNC Router Forum > Structure & Mechanics > 30. Y-Car
Old Mon 30 August 2010, 02:23
Red_boards
Just call me: Red #91
Setting up to weld square
I've read these threads and have a question about getting the vertical faces perpendicular to the base.
Will using magnetic braces be accurate enough (pic below) if the base is clamped to a flat base or is a firmer hold needed on the vertical faces to prevent distortion when the welds cool?
You can see the magnets in question (the BIG x-beams are underneath)
PS I've clipped the ends of the car in place. The "slots" cut in the end plates are diagonally opposite, rather than directly opposite - is this correct? I haven't seen any pictures where I can confirm for sure and the plans are silent on this (or my reading of the plans is!)
Old Mon 30 August 2010, 04:12
Hi Red
Diagonally opposite.
To set the car straight Myself and AusMaddog and Skippy used threaded rod to set everything straight in the middle of the car.
Setting the Y-axis square to the X-axis Gerald_D 20. Gantry 10 Fri 12 October 2012 01:44
Bolt only - no weld? servant74 10. Base Table 28 Wed 29 June 2011 14:47
Base table out off square m_leblanc 10. Base Table 6 Sun 22 August 2010 13:06
Setting the Z-slide square (perpendicular) to the table top blakekoehn 40. Z-Slide 10 Thu 11 February 2010 16:08
Is there more to cut & weld before painting? DocTanner Archives 6 Thu 25 January 2007 01:28
