Old Thu 08 May 2008, 02:08
ozanblotter
Just call me: OzanBlotter
Izmir
Turkey
80V @ 8A Microstep Drivers as Kit !!!
If you need drivers with following specs :
Max Voltage : 80V
Max Motor Current per Phase : 8A
Unipolar Microstep Drivers (6 or 8 Cable Motor)
Current Reduction (Saves Power %50 when there's no movement independently for each axis),
Full Step - Halfstep - 1/4 - 1/5 - 1/8 - 1/10 - 1/16 Microstep
And many other technical details, i supply them as kit including double sided PCB + Components + Videos + Documentation etc. :
http://www.sahibinden.com/microstep_...XQQdisplayitem
Each Driver is 360 $, but for friends over Mechmate Forum, below is my prices :
1 Driver : 240 $ (156 €uro)
2 Driver : 440 $ (286 €uro)
3 Driver : 600 $ (391 €uro)
4 Driver : 720 $ (469 €uro)
Also, there are interface boards and relay boards, two board works in parallel, so it's easy to connect them together just with 2x5 cable (i include cable,too). You can control anything with PWM and Relay Board, two color or one color LED connections, Switch connections etc.
And here is my LPT interface Board Prices as kit including PCB + Components + Documentation etc. :
4 Axis (or 3 Axis + PWM) : 120 $ (78 €uro)
Relay Extension Board : 120 $ (78 €uro)
Regards,
Ozan
