Old Mon 09 September 2013, 02:44
litemover
Just call me: Chris
Auckland
New Zealand
Drilling multiple plywood sheets at one time
Hi all,
Just a quick question, I have a job to drill approximately 8500 8mm holes in several sheet of 15mm ply and I'm wondering if it would be advisable to drill through say 3 sheets at a time to reduce the time it takes or is there something that would prevent this from being appropriate?
Thanks for any help,
Chris
Old Mon 09 September 2013, 03:33
If you can ensure the ply wood sheets doesn't move a micron during drilling you should be able to drill multi layers.
Old Mon 09 September 2013, 03:36
litemover
Just call me: Chris
Auckland
New Zealand
If I secure it in all four corner holes over a 2400 x 1200 sheet size plus maybe 1 in the middle would that do it Ken? Then Manual Drill the 5 screw holes after the sheet is finished.
Thanks!
Old Mon 09 September 2013, 04:04
I don't think so. but you can try. Worst case is a broken bit.
Damn, imagine how much time you will need to drill before MM... Human are greedy animal... including me
Old Mon 09 September 2013, 11:43
I would also suggest (if you didn't do this already) is use a real drill bit in your spindle.
You will be able to feed much quicker.
Old Tue 10 September 2013, 00:35
Mrayhursh
Just call me: Hurshy
Riverview, Florida
Sean, MechMate
Sean do you have a running Mechmate?
Old Tue 10 September 2013, 07:18
Peck drill them Chris if you are worried about clearing the debris.
Old Tue 10 September 2013, 08:08
Hurshy,
Not at the moment.
In the process of building another. #5 is gone. #28 is in town and accessible, so I am not without access. Also, Nils has number #12 and he is always Mr. Helpful and let's me come over and play if I need to.
It's good to have friends with MM's nearby!
Old Thu 12 September 2013, 03:21
litemover
Just call me: Chris
Auckland
New Zealand
Just curious, what would be the best feeds and speed for a solid carbide drill bit peck drilling through 2x sheet of 12mm ply at a time so I don't chip the bottom layer? Also what are the best peck level percentages? Want to make this a quality job. I found some high speed drill bits which should work well but just wanted to check speeds and feeds. Thanks!Chris
Old Thu 12 September 2013, 04:15
If you really serious about producing quality job, drill a sheet at a time.
No exact answer to you questions. just gotta trial & error.
Old Thu 12 September 2013, 04:16
Hi Chris
All I can suggest is run a few tests.
An up spiral will always leave the bottom clean, it's the top that burrs up.
Old Thu 12 September 2013, 06:14
litemover
Just call me: Chris
Auckland
New Zealand
What if I use a compression spiral up and down? Would that be better than a twist drill?
Old Thu 12 September 2013, 07:03
Hi Chris
I am running out of expertise here as I only ever do small amounts and use the cheaper general duty carbide bits (upcut spirals).
I did a plywood job for a mate of Andrew on the forum here and used an upcut spiral but cut the presentation face down on the table.
That give you a good face (the face you generally see) and one that needs touching up.
I understand you have to buy the downcut upcut spirals for the specific material thickness, no idea where to get them locally.
Suttons do make some fabulous quality end mills here in Australia so that might be a place to start.
Old Tue 17 September 2013, 18:13
litemover
Just call me: Chris
Auckland
New Zealand
Thanks Ross.
I've ended up with a Forstner type bit but it blows out the back side with lots of chips. I'm sure if I go slower it will be ok.
Old Wed 18 September 2013, 15:18
normand blais
Just call me: Normand
montreal
A compression would not help ,since the bottom part of the bit is up cutting so it might chip the top when entering . I have never use them from what i understand you have to cut in one pass with them,entering sideway
Old Thu 19 September 2013, 05:35
Norm….
Logicly, you’re not too far when “from what i understand you have to cut in one pass with them,entering sideway “ !
But sorry, yessss this type tool will / may be of good help !!
But the way this type ( compression) should be used is with the 2 steps approach !
1st is making a rough pass, say a few thousand offset the desired final cut / path and then, make a finish pass along the desired path.
That way you get best of both world, a roughing tool making just that….rough cut, quick and done !..... and then, a great finishing tool for any laminated ply board!!
Robert
Old Thu 19 September 2013, 08:20
normand blais
montreal
me are talking about drilling holes here
Old Fri 24 September 2021, 06:08
AlexTup
Just call me: Oluluron
AlexTupCN
Russia
Send a message via ICQ to AlexTup Send a message via AIM to AlexTup Send a message via Yahoo to AlexTup Send a message via Skype™ to AlexTup
I am going a different direction in beefing up the engine beds...Im not worried about the plywood.
Im just curious as to the actual reason for it being there in the first place.
Old Sat 29 October 2022, 01:23
GalenEi
Just call me: Otysipode
GalenEiQC
Send a message via ICQ to GalenEi Send a message via AIM to GalenEi Send a message via Yahoo to GalenEi Send a message via Skype™ to GalenEi
sissy slut assignments. buy essays online
Sherman Bates from Homestead was looking for sissy slut assignments
Deangelo Young found the answer to a search query sissy slut assignments
help writing essay paper >>> ESSAYERUDITE.COM <<< where can i buy essays online
movie theaters trailers
cover letter phd
solve for x word problems
year 2 homework sheets
doing homework quotes
coastal erosion case study
art and design personal statement
private peaceful essay
power point slide
best personal statements
thesis about abortion
internet assigned numbers
solving area problems
u movie rating
proposal in research
homework for grownups
solving energy problems
cover letter for admin assistant
what to write a college essay on
covering letter cv
homework sheets year 4
reflective writing essay
mba thesis
solve the following initial value problem
creative writing descriptions
university of east anglia creative writing
homework in primary schools
writing an elevator speech
literacy homework year 5
natural law essay
solving word problems with fractions
essay on helping someone
mother tongue amy tan thesis
thesis statements for the great gatsby
anonymous report to social services
conclusion and discussion
good thesis
trail of tears essay
ethical consideration in research proposal
supersize me essay
sunday books
plagiarism essays
michele obama thesis
ict homework help
what is a argument essay
river nile facts for homework
dr ross greene collaborative problem solving
writing a remembrance speech
persuasive essay topics
write my paper
buy essay
thesis writing service
good research proposals. essays order
thesis for a speech. write my papers
manchester university creative writing. writing paper service
solved problems in differential equations. term paper writing help
clinical problem solving. research papers write
configurable limit switch. for multiple uses. zumergido 70. Control Systems 0 Thu 27 September 2012 11:39
Multiple routers/spindles/drills? robertmonroe 50. Toolheads 4 Fri 02 April 2010 23:38
Bearing Skates for multiple uses. ddoggett The Market Place 22 Thu 04 March 2010 18:13
Non-Trade Pricing for 4'x8' sheets of HDU/SignFoam? dmoore General - MM Operating 1 Sat 03 May 2008 21:51
Table legs for storing sheets underneath vadeem 10. Base Table 2 Fri 01 December 2006 01:26
