Old Thu 30 August 2018, 04:41
ricdu34
Just call me: eric
gabian
France
position error for cable chains
as wrong, I did not weld the end of the gantry properly.
The one planned for the passage of the cables is on the wrong side (in front of the gantry)
as we can see on the first picture, I will have to reverse the parts that support the cable chain of the gantry.
I understand that I will have the engine behind.
Can I have other problems than the media to modify?
je me suis trompé ,je n' ai pas soudé l' embout du portique correctement.
Celui prévu pour le passage des cables est du mauvais coté(devant le portique)
comme on peux voir sur la premiére photo ,je vais devoir inverser les pieces qui supporte la chaine de cable du portique.
J' ai bien compris que je vais avoir du coup le moteur derriére.
est ce que je risque d' avoir d' autres probléme que les supports a modifier?
Old Thu 30 August 2018, 06:20
ifffff
Just call me: Ivo #38 & #130
Parnu
Estonia
I made same mistake when was building #38. Put that cable carrier to other side of gantry.
Incrementing error in cutting?? giggler Troubleshooting 7 Tue 13 September 2011 08:29
Spiderplate error (booboo when drilling) oddname 40. Z-Slide 14 Thu 04 March 2010 14:29
Can backlash give a cumulative error? Gerald D Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 43 Sun 31 January 2010 13:08
Re-alignment after dis-assembly - getting all parts into position at the new location kanankeban 10. Base Table 11 Sun 25 January 2009 12:48
10 20 235 Y-Rail Clamp Strip - getting it into position . . . . dmoore 20. Gantry 12 Thu 05 June 2008 09:39
