Old Thu 18 December 2014, 20:58
notimeforwork
Just call me: kwguy
kitchener, ontario
Welding.
Is there a welding sequence for the table that minimizes distortion? I plan on using a smaller flux core mig (not too much heat) - but I am still concerned about keeping the table square while welding and would like to know if there's any proven methods.
Old Thu 18 December 2014, 21:47
Castone
Just call me: Leo #41
Soddy Daisy , Tn
I bolted my wood table on , before I welded mine out, did not move. I just skipped side to side.Just tack it up good, then bolt your spoil board down, then weld it out but make sure it is square and level.
Old Thu 18 December 2014, 22:49
Yes, there is a sequence. Its in the plan & in many of the building threads.
Old Thu 18 December 2014, 23:51
notimeforwork
Just call me: kwguy
kitchener, ontario
I see a sequence for welding the gantry spider, but if you could be more specific to the exact page of the plans where I can see a sequence for the table.
Old Sat 20 December 2014, 14:29
http://www.mechmate.com/forums/showthread.php?t=230
It is actually detail here in the forum.
The forum numbering is the same as the plans on purpose. This is the online manual.
Old Sat 20 December 2014, 16:02
notimeforwork
Just call me: kwguy
kitchener, ontario
That is not the table..
Old Sat 20 December 2014, 22:51
The stationary table itself does not need, or have, a welding sequence. The final stiffening of the table is the spoil board. Rails are aligned with shims.
Old Sat 20 December 2014, 23:42
notimeforwork
Just call me: kwguy
kitchener, ontario
Thanks Gerald.
Old Sun 21 December 2014, 15:51
...my apologies, I didn't fully realize it was the table portion you were asking about.
Welding Up The Table!- Maracaibo, Venezuela hevertg Construction started, but not cutting yet 65 Fri 10 April 2015 23:57
Welding Info Metalsmith Miscellaneous / General / Whatever / Catchall 1 Sat 28 April 2012 15:56
Welding equipment & techniques smreish General - MM Build 96 Mon 22 November 2010 01:48
Question RE old welding electrodes... Zouave General - MM Build 5 Sat 03 April 2010 03:23
Welding rack sections together Jayson Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 0 Wed 24 December 2008 14:13
