Old Sat 08 March 2014, 21:01
SEIKI
Just call me: MARK
TROY MI.
Table/base prep for painting
Looking for advice and opinions from those that have painted their machines, how much effort did you put into preparing for paint and are you happy with the results?. The small parts I can sandblast in a cabinet sandblaster but the base obviously is a whole different animal. Thanks for your opinions and experiences.
Old Sun 09 March 2014, 07:52
I just brushed off any scale with anything that worked then cleaned with mineral spirits, let dry, sprayed primer and paint. Some go full boat by sandblasting, prime and paint with automotive type paint & sprayer which is what I wish I had done but could not because of the weather (and patience).
Old Sun 09 March 2014, 08:02
You can use a closed cell foam cabinet roller. You could also put some hardener in the paint to make it tougher.
http://www.tractorsupply.com/en/stor...e?cm_vc=-10005
http://www.tractorsupply.com/webapp/...=&cm_vc=-10005
http://www.lowes.com/pd_45123-11591-...ler&facetInfo=
No need to get to fancy with it since it will have stuff mounted all over it. Also if you two tone it by painting a few things like motor plates and rails black, it will also keeps ones eyes "busy".
I have painted equipment and boats with this method with good results.
Old Sun 09 March 2014, 09:47
I hit mine with a wire brush on a harbor freight slow speed buffer, just to knock the big stuff off, since my main beams were used and weathered.
Then like Tom, I wiped with a bunch of rags and mineral spirits, then primed and painted with Rustoleum products and a cheap HF HVLP gun.
Its a tool, not a work of art.
Make it look nice, but don't go overboard or you'll be afraid to get it dusty...
Old Sun 09 March 2014, 10:08
dbinokc
Just call me: DB #118
Oklahoma
So far I have used 14 cans of spray paint on my machine, 6 of primer, 6 blue and 2 black. I may need 1 more blue, before it is done. In my case, I just pressure washed all the steel, before welding and painting.
Old Sun 09 March 2014, 12:09
SEIKI
Just call me: MARK
TROY MI.
Thanks guys this is the kind of info I was looking for. Thanks for the links Mike I haven't decided if I will roll it or use a spray gun. One thing for sure is I need the weather to warm up so I can get it outside.
Old Sun 09 March 2014, 12:13
ger21
Just call me: Ger
Detroit, MI
At least the sun comes out now.
Old Sun 09 March 2014, 12:23
SEIKI
Just call me: MARK
TROY MI.
Yes just having the sunshine raises the spirits and changes your mood. Makes one realize how much you miss it. Never thought 40 degrees would be a heat wave.
Old Sun 09 March 2014, 13:34
My shop is actually 65 inside today. been a couple months since its been that warm.
Old Sun 09 March 2014, 13:51
I can't get mine up to that even with a jet heater, except today, and of coarse I'm not there today. Enjoy it while you can.
Side Raisers instead of a Base Table sprayhead 10. Base Table 5 Fri 11 October 2013 11:09
Removable Base Table Hardouin 10. Base Table 10 Sat 23 February 2013 10:58
Base table out off square m_leblanc 10. Base Table 6 Sun 22 August 2010 13:06
Converting Base Table For Plasma Cutting rkrecak 10. Base Table 3 Tue 18 December 2007 11:55
Wood base table option Loren Gameros 10. Base Table 11 Fri 08 June 2007 23:43
