Old Tue 15 November 2011, 19:30
SLINK
Just call me: SLINK
CHURCHVILE NY
Cheaper drives
Does any one know of good axis drives that i could replace or rather use instead of the gecko 203v drives usin nema 34 motors and the pmdx-122 bob board
Old Tue 15 November 2011, 20:11
keling - affordable units (be sure to pick the correct step and current value for your motors)
uirobot - used on a few MechMates already
automation direct
gecko G540 drive - The most affordable solution with the right choices.
Also, you don't need the G203 series drives, others in the gecko family will work.
Old Tue 15 November 2011, 21:08
SLINK
Just call me: SLINK
CHURCHVILE NY
Thank you for a quick response i will look at this drive
Old Thu 17 November 2011, 15:02
IN-WondeR
Just call me: Kim
Randers
Denmark
I have used Leadshine models drives for the last build, and they work like a charm. Probably not the worlds best, but they do the job, and are affordable.
Old Thu 17 November 2011, 18:59
SLINK
Just call me: SLINK
CHURCHVILE NY
Old Thu 17 November 2011, 21:30
you might want to check these out.
http://www.tinycontrols.com
Old Sat 19 November 2011, 12:44
SLINK
Just call me: SLINK
CHURCHVILE NY
Thanks a lot ken c check the site and emailed for a price people on mechmate forum are great help 30 yrs as a machinist cnc but the electronics part is where ui can
can"t afford to make mistakes
Old Mon 28 November 2011, 07:31
quadtech
Just call me: Prasad
Hyderabad
Thanks for the link, Ken. Interestingly, they are located in India.
Anyone tried them out? The drive looks pretty slick.
Browsing through the site, I came across a very nice looking
BOB too. This could be a pretty good option for builders in
this region.
http://www.tinycontrols.com/parallel...out-board.html
Old Tue 29 November 2011, 23:51
I am already using these on my CNC machine - the surprising fact is the the drives were designed by a fellow Mechmater - Anil - his thread is here
Folks here could also ask for a discount
attached is a picture of the drives on my new machine.
Irfan
Old Wed 30 November 2011, 02:50
Nice. What are the caps for?
Old Wed 30 November 2011, 03:16
aniljangra
Just call me: Anil #44
Delhi
Those caps are needed because he used long and thin wires to connect power to drives
Old Wed 30 November 2011, 03:23
Ahhh.... Channel isolation & better PS Zo
A thick 12g loudspeaker cable should save the trouble nicely ?
Old Wed 30 November 2011, 03:25
Anil, would you kindly elaborate the protections you put into your drivers?
Old Wed 30 November 2011, 03:33
aniljangra
Delhi
Thanks Ken for your keen interest, basically drivers are protected for current at the outputs making them protected from over-current, miss wiring and short circuits at the output.
So you can only destroy them by connecting the power in reverse (even then the fuse blows) otherwise they are safe to common miss use or miss wiring.
WTB: Belt drives JamesJ The Market Place 1 Sat 27 August 2011 21:46
Spindle and vfd cheaper than I can get a decent router jwt 50. Toolheads 23 Tue 19 October 2010 04:35
Belt Drives?? zigmart The Market Place 1 Thu 22 July 2010 21:12
Build a functional MechMate at lowest cost - what can be done cheaper? Gerald D General - MM Build 87 Sat 06 March 2010 19:21
Steel sizes & gauge substitute info! (can we make it lighter and cheaper?) Robert M 10. Base Table 17 Tue 06 May 2008 10:51
