Old Mon 21 July 2008, 22:14
jbmclain
Just call me: Joe #42
Birmingham, AL
What to shim with?
Well one of my 7" C-Chanel has a dip in it.
That causes my rail on that side to dip as well.
Can someone help a brother out?
Joe
Old Tue 22 July 2008, 00:30
Strips of beer (or softdrink) can:
Old Tue 22 July 2008, 05:12
Joe is your table welded up yet? How do the legs attach to the beam? How are the braces attached? Post a picture of the entire side showing the beam, legs, braces and lower cross member.
Old Tue 22 July 2008, 07:11
There is also these,
McMaster Carr
Part Number - 9011K19
Description - Shim Stock Sheet Low Carbon Steel, .020" Thick, 8" X 12",
Unit Price - Packs of 5 $12.71
Old Tue 22 July 2008, 12:20
jbmclain
Birmingham, AL
That seems easy enough. Thanks for the help.
Joe
Old Thu 30 December 2010, 19:48
JamesJ
Kansas
If you are looking for pre-cut shims take a look at McMaster-Carr P/N 9302K25. These are alum. slotted shims in a variety of thickness.
Old Fri 31 December 2010, 02:23
washers work
Old Fri 31 December 2010, 04:46
Any thing with stable & consistant thickness will work, including gold & silver Diamond too...
Happy New Year!
Old Sat 01 January 2011, 13:58
Easy thing to do is use soda/beer cans. You can do a make shift die cut of them to a uniform shape by taking a small section of pipe and sharpening it and then arbor pressing into "donuts". Then, gang drill them for the center hole.
..or you can spend money and buy shims.
I personally use a deck of cards for my shims. They are stable, waxed and last forever - plus easy to cut. I learned from a field mechanic years ago on this technique to align shaft pillow blocks on really big machines. Deck of cards was really cheap and fairly non-compressible.
