Old Tue 21 June 2011, 10:08
gixi
Bucharest
Romania
Screw M7
Heeelp ! I just started to build a new cnc machine, my own design... For this machine I did some serious shopping and the major objective was to use linear slides. For the Y axis I found on eBay a linear slide from THK 25mm with flange. The price was good, the items are new but the holes for fixing the slide has a "special" dimension 7mm. Finding screws with this dimensions become a nightmare . Did someone know from where I can buy such screws?
Old Tue 21 June 2011, 10:29
7mm is a typical hole size for a 6mm screw.
Old Tue 21 June 2011, 18:28
gixi
Bucharest
Romania
As always you are right !
When I finish reading all the info from their site (THK) I realized that is no such screw in the installation guide... .
I forgot one of the mottos of this site: READ, READ and READ again.
Thank you Gerald
Old Tue 21 June 2011, 18:37
gixi
Bucharest
Romania
One more thing: each part of this project before sending to the laser machine was cut with MM for testing. It's good to build a machine using yours .
What can I say: somehow MM is the mother of the new machine .
Old Wed 22 June 2011, 14:42
PEU
Just call me: Pablo
Buenos Aires
do you have a build log for the new machine? at cnczone?
Old Thu 23 June 2011, 04:36
gixi
Bucharest
Romania
Yes I started the second project and this is the link http://www.cnczone.com/forums/diy-cn...d_machine.html.
Looking at the new structure, each day I get to the same conclusion:next step linear bearings on my MM.
Gecko 201X Adjust Screw tnarch 701. Motor Drives 2 Wed 23 March 2011 10:11
3d Mold divot issue - SOLVED - Loose screw holding pinion gear salewis Troubleshooting 41 Tue 23 November 2010 12:36
Grinding flat spots on shaft for set screw seating kanankeban Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 8 Fri 02 July 2010 01:33
Screw threads - inch & millimeter Gerald D Golden Resources 1 Mon 09 March 2009 01:54
