Old Sat 28 August 2010, 04:19
sprayhead
Just call me: Francis
sydney
How to guarantee zero backlash when mounting the motor mounts...
HI guys
When mounting the whole motor assembly to the gantry, how do we guarantee we get zero play with the screws and washers?
Do we need a screw that fits the gantry and motor mount hole with a very small amount of play? .05mm to each side or something similar?
Because If I can picture it right, we don't want to tighten the screws too much otherwise the motor bracket will be "hard" and pretty much ignore the spring... How tight have you guys tightened them screws?
thanks,
Francis
Old Sat 28 August 2010, 05:40
AuS MaDDoG
Just call me: Tony #71
Brisbane
Hi,
The bolts can be tightened fairly tight and the size of the bolts is called up in the drawings. The use of teflon washers on these bolts allows movement and for the spring to work.
Hope that helps.
Tony.
Old Sat 28 August 2010, 07:46
sprayhead
sydney
thanks tony,
I was just having a look at the drawings... and,
The holes are .1 mm bigger then the nominal screw diameter. So, in theory, we would have a .05 backlash.?
But I suppose if we tighten the 2 screws enough, she'll be stiff and playless.
btw, the long hole is for a M8 screw and the Pivot hole is for a M10.
F.
Old Sat 28 August 2010, 08:30
Francis, in theory we have backlash at that point, but in practice we don't see it.
We tighten the hinge screw until the motor stays up under its own weight. The other smaller screw at the slot is tightened only lightly.
Old Sat 28 August 2010, 09:19
sprayhead
sydney
Thanks Gerald,
good to see you are still active up here.
Francis
Backlash in the gearhead of the Oriental Motor PK296A2A-SG7.2 Gerald D Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 37 Sun 22 September 2013 08:58
Backlash compensation lumberjack_jeff Troubleshooting 10 Sat 14 November 2009 08:30
Router mounts - adapting to the MM slide lumberjack_jeff 50. Toolheads 16 Mon 19 October 2009 23:25
Mounts for Chinese Spindles dacostad The Market Place 1 Mon 24 August 2009 23:56
M5 10 160 A & M5 10 200 A Motor Mounting Bolts dmoore Motors & their mountings 3 Wed 16 April 2008 03:06
