Old Sat 07 August 2010, 15:31
ahe_1990
Just call me: Adam
Birmingham
Aluminium Wheels?
Due to the price of Steel Vee Rollers, I am currently testing my mechmate with plastic homemade Vee Rollers and they seem to be good at the moment. What do you think to making them out of aluminium. Can anyone see a problem?
Oxidization? (Sandpaper)
Old Sat 07 August 2010, 21:41
The have been made from Brass and Ertalyte.
Old Sat 07 August 2010, 23:55
Regnar
Just call me: Russell #69
Mobile, Alabama
I would make a few extra just incase they wear out but if you are having no problems with plastic the who is to argue.
I wouldnt worry that much about oxidation. The rails will take care of that after a few pass overs. Depending on the environment you might have problems with corrosion building up between the bearings and the V wheels but use a nice primer when pressing in the bearings and it shouldnt give your problems for a very long time.
Something also consider is that plastic has bounce back where aluminum will just wear away. So any nicks or burs on the rails will wear away at the aluminum faster.
V-Wheels machined from plastics MariusL Rails & Rollers 40 Sat 30 June 2012 15:06
Anyone have the MM mounted on wheels ? Stepinwolf General - MM Build 13 Mon 14 December 2009 03:33
What type of cutter to use and what feeding speed to cut aluminium hennie Cutting various materials - bit selection, feeds, speeds 1 Fri 24 July 2009 10:24
Routing or cutting aluminium WARBIRD Cutting various materials - bit selection, feeds, speeds 21 Sun 31 May 2009 14:09
6mm Aluminium leonrocks Archives 1 Sat 16 February 2008 07:20
