Old Tue 08 June 2010, 00:30
albertoslayer
Just call me: albertoslayer
san blas
Mexico
Pk296a2a-sg7.2
Hi
I want to buy 3 PK296A2A-SG7.2 motors for my mechmate, and I want to know if they can work with a 63 VDC power supply and g203v drives, and the final question is how long is the diameter of the shaft?? because I want to conect them direct to the pinion and my pinions are 1/2 inch of diameter, can I put these pinions in the shaft of these motors???
How it work if I don´t use the 3:1 reduction?
Thank you, And Sorry for my bad English
Alberto
Old Tue 08 June 2010, 01:19
Alberto,
The PK296A2A-SG7.2 motor has 1.5mH of inductance if you wire it half-coil. So MAXIMUM voltage is about 40 VDC if the motor is wired half-coil. If you wire the motor bipolar-series, the inductance is 6mH, so you could use a 78VDC power supply; however, wiring a motor bipolar-series greatly reduces the motor's top speed.
I use a 35VDC power supply with my PK296A2A-SGxx motors and I wire the motors half-coil.
The shaft is 1.14-inches long (29mm). and it is 0.5-inches in diameter (12.7mm). Many people use a 1.25-inch or 1.5-inch pitch diameter spur gear with that motor.
You would not use a 3:1 belt drive with that motor. The motor already has a 7.2:1 gear box attached.
Backlash in the gearhead of the Oriental Motor PK296A2A-SG7.2 Gerald D Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 37 Sun 22 September 2013 08:58
Aussie Builders - Anyone Wanting to Sell Their PK296A2A-SG7.2 rotorzoomer The Market Place 3 Sat 10 April 2010 23:01
Resistors for G504 and wiring for PK296A2A-SG7.2 motors (unipolar) jehayes 701. Motor Drives 7 Sun 15 November 2009 19:16
motor problems vexta pk296a2a-sg7.2 chopper Archives 1 Wed 29 April 2009 00:37
Are these the same: Pk296ae-sg7.2 (metric) = Pk296a2a-sg7.2 (inch)? gixi Motors & their mountings 15 Wed 26 November 2008 14:39
