Old Sun 07 September 2008, 13:59
Barman
Just call me: Bart #36
antwerpen
Belgium
Cuttings signs and insects #36 - Antwerpen, Belgium
At the beginning of this year, I decided to build a CNC hobbymachine .
After a few weeks surfing on the Internet I came to this amazing MechMate site of Gerald D
I could not believe my eyes. A site with real plans and a great support . This is really fantastic. After several months of reading, I have also decided to build a MM for MDF board of 122 x 244 cm
I have no CNC experience and the construction of this MM will be a new challenge for me.
When the MM is ready I’m planning to build some kitchencabinets as hobby.
So, last month I have ordered : 14 x GW3 (guide wheels) and 6 x B3X (eccentric bushing) at Rick Hoback of the firm Superior Bearing Company.
Last week my "Mamba set" arrived from Denmark, made by Kim Mortensen (great job indeed) with a corresponding gaugeplate.
My iron is ordered at work: 18 m UPN 80 , 6 m UPN 180 and 6 m tube 100x50x3 mm
(Hopefully it will be delivered this month)
Most of the work such as sawing, grinding, drilling, I plan to do at work ( no noise and dust at home ) . After the working hours of course, so this will take a while I think.
My goal is to finish the mechanical part : the table , gantry, z-slide at the end of this year.
Meanwhile I have all my X and Y - rail cut with a 230 mm cuttingdisk at 28,5 mm.
My intention is cutting the rail at 28,5 mm and then grinding the rail using the railskate to 28 mm .For this I made a support for a grinder of 2300 W with a diskdiameter of 230 mm .
It went reasonably well. I needed 1 cuttingdisk for 6 meter.
So a total of 2 pieces . It lasted about 20 minutes to cut 3,5 m rail .
Unfortunately, the cuttingdisk jammed at a certain moment while I was cutting the first X-rail
( The moment you're almost through the 6 mm , is the most dangerous for jamming the disk , ... I learned )
Therefore the railheight of one X-rail is 27,4 mm at a certain place for approximately 40 cm instead of the needed 28 mm . Therefore I will reduce both X-rails to a railheight of 27 mm.
Will this be a problem for the future, or should I make “ one” new X-rail with the railheight of 28 mm ? (Hopefully it is admitted to reduce the height , because all the L-iron 60x60x6 is out of stock)
Old Sun 07 September 2008, 14:34
Bart if you have anymore rails to cut, do this it works. When your just before cutting through start climb cutting, moving the grinder only in the direction it wants to go, hence the term "climb cutting".
It saves wear and tear on the cutting wheels.
Old Sun 07 September 2008, 14:56
Bart, the 27mm is absolutely no problem.
Good to see the progress!
Old Tue 09 September 2008, 08:07
Barman
antwerpen
Belgium
Thank you for your advice, but if the 27 mm railheight is also right it saves me a lot of work Today, my 18 m UPN 80 arrived at work.
So , I know what I am going to do this weekend .
Making my cross bearer and finishing the X – Y rail ( trying to ?? )
Old Mon 22 September 2008, 04:51
Barman
antwerpen
Belgium
My 8 cross bearer are made. I used an L-iron as a jig . All the holes are 6,5 mm except those of the main beam's these are 13 mm. In these holes of 6.5 mm I will tap M8 thread and uses countersink bolts for the support board .
I did some testing for grinding the 2 x 45 ° angles for the X – Y rail .
Old Mon 22 September 2008, 21:15
Bart,
Sounds like you are making good progress. I wish you the best.
Old Mon 22 September 2008, 21:34
Bart,
Nice to see progress.
How did your testing for the angles go? Pictures would be great.
Old Tue 23 September 2008, 06:10
Barman
antwerpen
Belgium
Hey, it's good to get support in this project because there always will be large or small problems , which can be solved .
He Greg , about " my testing " :
I welded a flat bar of 30x8 mm (or the waste of the 60x60 L-iron ) to an L-iron and fix it on my workbench (total length ca. 60 cm). In this way, I can practice with the railskate without making mistakes on my original rails.
In my first attempt the angle was greater than 90 degrees.
In my second attempt the angle is 90 °, but my the flanks of the corner are not equal (picture will follow).
Here I still do something wrong , so I have to do some reading , why ?
I also made another setup for the grinder .
Inspired by the example of Hennie.
The aim is also to do the gaugeplate with it .
Old Wed 24 September 2008, 06:12
Barman
antwerpen
Belgium
Some pics of my tests:
Initially I tried the setup with the railskate (tipping method).
Later, I tried this setup. My results remains the same, no equal flanks.
This photo is my worst result.
Is this acceptable ???
Tonight I will try again to find out what is going wrong and to get a good result.
Old Wed 24 September 2008, 07:13
Uneven sized flanks are acceptable if they are consistent along the length of the rail.
Old Thu 25 September 2008, 06:54
Barman
antwerpen
Belgium
Hey,
I thought that technically , it could not hurt.
But I do not understand how this could happen, because I always
make the same movements in the same direction.
And my referencetable is of 30 mm plywood.
Old Wed 29 October 2008, 13:34
Barman
antwerpen
Belgium
Hey, I'm still alive.
Here are some pic’s of my "slow" progress.
I did my Y-rail's and welded my gantry .
This week I wanted to weld my table but I could not find the right welding machine , so .. it will be for the next time .
For my router table I used 7 cross bearers instead of 8 and a 30 mm MDF support board
Other things that I collected are:
4 large wheels (total height = 16 cm), 1 PC pentium 4, 1 electrical cabinet and support
for the legs.
Old Wed 29 October 2008, 23:27
Nice going Bart....in the land with the biggest and best variety of beers...according to me
Old Thu 30 October 2008, 05:23
Barman
antwerpen
Belgium
Yes , there are more then 400 different kinds of beer in our country.
My favorite is "Den Duvel" made in a local brewery.
"Schol, Santé ..." on the build of the MechMate.
www.duvelusa.com/heritage.php?cat=belgian
Old Thu 30 October 2008, 05:41
Wish I was there to share a "pilsje" with you. During my 5 years in Holland we visited the Belgium Ardennes often...
http://en.wikipedia.org/wiki/Ardennes and then our drinking beer was JUPILER, but to wash our mouth out, we had a nice cold Duvel or a Westmalle Triple
Groetjes, Kobus
Old Thu 30 October 2008, 07:13
Barman
antwerpen
Belgium
That would be nice .
This evening I ‘m leaving on weekend to the "Ardennen".
I think this time it will be " Rochefort 8° - 10° " .
Old Thu 30 October 2008, 08:08
How about the Trappiste Ales? I love Duvel but I love those too!!!
Old Thu 30 October 2008, 10:55
Mitchells & Amstel for me and if available a Corona.
Old Thu 30 October 2008, 12:14
Barman
antwerpen
Belgium
There is a Dutch saying " Drink met mate(n)! ".
This means " Don’t drink too much" but sometimes , this is also known
as " Drink with your friends ! ".
Old Sat 27 December 2008, 14:37
Barman
antwerpen
Belgium
A Happy New Year to everyone .
Here is what I've done lately.
www.youtube.com/watch?v=_kAoBhdJbVc
Some things delayed me , but it goes in the right direction
When I was grinding the 2x 45 angels of the X-rail my new Bosch grinder broke down .
I finally got a new one after 2 weeks .
I made a mistake with the distance between the X-rail .
Gauge Rod = Length Y (1220) + 461 = 1681 mm
This is the distance that I used to dril the X-rails in the Main Beam .
When I put the Gantry on these X-rails I noticed a difference of 6 mm .
So , I have enlarged the holes of the X-rail from 12 to 13 mm.
Now they fit correctly but the bolts for the rails are at the end .
In the future I will make slip holes in one X-rail for an optimal alignment and use .
Old Sat 27 December 2008, 16:55
isladelobos
Just call me: Ros
Canary Islands
Spain
Good video Bart!! Thanks
We see the quality of the design and maker.
Old Tue 17 March 2009, 09:08
Barman
antwerpen
Belgium
MechMate is painted and back assembled.
I know bad points for me.
The RAL is 5021 instead of 5010.
Originally , I bought these paint for my outside metal stair , several years ago .
But the color was not right for my wife ...
I painted everything with a paint role.
It took me about 2 weeks.
Each day approximately 2 hours painting. I have 2 layers established.
Only the Y-car, I tried spraying with a cheap spray gun from a local store.
This was a big mistake . The quality was bad and I still have to clean my garage.
Further I had a long wait for the “hold down shaft” and the “bearing support base”.
But now I have an extra set , maybe for later.
I only need to weld it on the spider plate .
Also I decided to buy 4 x PK 296AE-SG7.2 .
So, I have already bought the 4 x pinions : module 1 – Z = 36
Old Tue 17 March 2009, 10:01
Way to go. As always, use what you have. That blue looks close enough for me noticing....I wish my garage was that clean
Old Wed 18 March 2009, 00:15
Nice going ...the garage will quickly change once he starts cutting ..
Old Wed 18 March 2009, 00:25
I like that blue! Okay, everyone else must repaint now!
The best part of that paint is that it got used and didn't end up going hard in the tin. I wonder what percentage of the world's paint production, particularly solvent-based paints, gets dumped. . . . .
Old Wed 18 March 2009, 05:32
Barman
antwerpen
Belgium
I ‘m glad you all like that color.
I ‘m also very pleased with my paintingjob.
Almost sprayed !
My children love it too.
Proudly they tell everyone that “they have chosen the color of Dad's machine”.
Old Wed 18 March 2009, 15:16
Barman
antwerpen
Belgium
Today I did some homework on the powersupply:
Can someone please confirm my conclusion before I order.
A quick summary :
Used motors will be : PK296AE-SG7.2
Wire them half – coil .
MAX Voltage / Motor = 32 X SQRT(Inductance), so 32 X SQRT(1.5mH) = 39VDC.
TRANSFO :
230VAC/ 2x25 VAC will give 35 VDC after rectification .
The secondary windings will be put in parallel for max current .
This is the transfo I’m going to order :
http://be02.rs-online.com/web/search...duct&R=2238257
ELCO :
Formula : ( 80000*current motor) / voltage motor.
(80000 * 3) / 35 = 6857 μF * 4 steppers = 27428 μF
Selected Elco : 1 x 22000µF - 63 V
This is the elco I’m going to order :
http://be02.rs-online.com/web/search...duct&R=5436915
RECTIFIER: -> I have already
Secure with 4 x fast fuse of 3A
Fuseholder to order :
http://be02.rs-online.com/web/search...duct&R=3110009
Fuse 3 A to order :
http://be02.rs-online.com/web/search...duct&R=5421452
No Bleeder Resistor !
Also check my powersupply schema .
Any suggestions ?
Soon I can start with the kitchen project.
Old Thu 19 March 2009, 00:04
What drives are you using?
Those calculations perfect for G201 and G202 drives. For G203, you do not need fuses, they have fuses inside. Remember to order the resistors for the drives.
Old Thu 19 March 2009, 03:10
Barman
antwerpen
Belgium
The drives will be 4 x Gecko G203 V.
The resistor must be (36k – 0,6W) for the 3 A protection.
(Normally it is 0,25W, but I dont find it on the ordersite .So I think 0,6W will certainly do)
The resistor to order :
http://be02.rs-online.com/web/search...duct&R=0148865
Old Thu 19 March 2009, 04:19
That resistor will be 100%
I think the fuse in the Gecko 203 is:\
http://be02.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=541330 0, but I am not sure.
New here - Hofstade Belgium BIBIP Introduce yourself and start planning 5 Sat 16 April 2016 14:38
A new build and also a new start from Antwerpen, Belgium BartDeckers Introduce yourself and start planning 7 Sat 16 April 2016 03:00
And another MM will be built in Belgium bramvh Introduce yourself and start planning 9 Fri 15 April 2016 15:01
How to do Signs Lessons sailfl Miscellaneous / General / Whatever / Catchall 10 Fri 06 February 2009 05:03
