Old Tue 03 November 2009, 16:41
oddname
Just call me: frallan #57
skane
Sweden
DIY-rails Which type of angle iron must be purchased?
I might be going blind but cant find any info on the L-profiles.
How big is enough for them?? I'd guess they need to be 6mm thich atleast but is like 50x50 or 60x60 the way to go with the other numbers?
//frallan
Old Tue 03 November 2009, 17:31
ifffff
Just call me: Ivo #38 & #130
Parnu
Estonia
Material for rails is easiest to find 60*60*6 angle iron. It may be one side shorter too for example 30*60*6. 50mm wide rail is acceptable too but in that case may be threading beams be little more complicated because their inner side is rounded
Old Tue 03 November 2009, 19:20
Going blind…I don’t know…maybe !
Not reading the plans…I’d presume -> YEP !
Go to the download page, download the plans, then go to page M1 10 110 MB to see steel rail details. Take also note on all plans, pay attention to the “title block”, (the lower right box with the plan info) and notice in that box own upper left corner, there is often a reference of other plan related or “Higher drawing/s” to see !
Remember to read all plans a few time, get to know them almost by hart, then read lots, lots of threads & post….Then if you still wonder of something, yep, we will there to either direct you or assist you
Enjoy…Amicalement, Robert
Old Tue 03 November 2009, 21:10
Small correction to Robert: The drawing M1 10 110 M B was revised in June 2008 to revision C.
Old Sat 07 November 2009, 18:41
oddname
skane
Sweden
Another question, would the diy-rails works as Alu too?
The pre-made ones uses a smaller Alu iron but could it be done completely in Alu without the screw-on rails?
Old Sat 14 November 2009, 07:23
Alu will be too soft. Maybe okay for hobby use (2 hours per week) but it will not last for production (45 hours per week)
Old Sat 14 November 2009, 08:41
Conrado_Navarro
Just call me: CONRADO NAVARRO #55
OBREGON
Mexico
Send a message via MSN to Conrado_Navarro Send a message via Yahoo to Conrado_Navarro
Gerald.
I use aluminim rails (US$ 10 3 mts/pair , those ones you use on sliding doors, as you said they work excelent but I use them only 4 to 5 hrs/week.
Future improvement will be from steel.
Cutting the angle iron down with grinder and abrasive disk Alan_c Rails & Rollers 39 Mon 13 July 2009 12:15
Why the angle iron must be 2" tall (or less) before cutting down with grinder Gerald D Rails & Rollers 3 Sat 29 November 2008 14:46
Why does the angle iron have to be cut shorter for the rails? chopper Rails & Rollers 8 Thu 10 July 2008 22:28
M110110M Angle iron rails for X and Y axes Gerald_D Rails & Rollers 69 Sat 15 September 2007 18:17
Thoughts on the angle iron rails of the MechMate Sheldon Dingwall Archives 15 Wed 07 March 2007 15:07
