Closed Thread
Old Sat 28 November 2009, 18:37
shelbygt500buddy
Just call me: kyle
stuart fl
Bought Linear Rails, Help mounting (non-MechMate)
Hi, I have recently bought linear rails for my machine... standard guide ways and trains for them. Ok question is im not sure what the best way to mount them is. The will be mounted on top of a 10'x2"x6" 1/8" thick steal tubing...
Should i do something like a threw bolt and bolt them straight to the top of the 2x6? i would have to plasma square holes and weld tubing in the hole so i can acheive the threw bolt scenario. It would look something like this
Second ideal just drill and tap all the holes straight into the 2x6 but will the 1/8" thickness give enough treads?
And third ideal should i just get 3/16 to 1/4 steal laser cut the holes and tap those? then bolt or sticth weld to the 2x6?
Old Sat 28 November 2009, 20:17
cab. guy
Just call me: Ron
Boise,Id.
Kyle ,
Lets start with brand and style of rails. Suggest holding off on any further construction till you do more research. Look at Ezrouter (scorpion) and Kevin L.posts Then get back.Ron.
Old Sun 29 November 2009, 00:07
This is clearly not a MM build and this thread is probably going to be deleted. Suggest you go to CNCzone.
Old Sun 29 November 2009, 21:06
shelbygt500buddy
Just call me: kyle
stuart fl
Everything is based off the mm i had to go cheap on some stuff... i cant afford to get my stuff laser cut so i had to modify... I didnt realize you guys wouldnt respect that..
Old Sun 29 November 2009, 21:07
shelbygt500buddy
Just call me: kyle
stuart fl
They are hiwins but i just need suggestions and pros and cons on the ways i was questioning about mounting the rails
Closed Thread
It is CUTTING! Bolted Mechmate with linear bearings - Kansas, MO KevinL MechMates already cutting 53 Wed 22 May 2013 07:04
Z slide length, dimensioning the linear system. sprayhead Archives 1 Thu 10 July 2008 07:02
Bought my first part - Ogden UT David Smith Introduce yourself and start planning 2 Tue 24 April 2007 22:13
Thoughts on the angle iron rails of the MechMate Sheldon Dingwall Archives 15 Wed 07 March 2007 15:07
Linear bearing Z slide Dirk Hazeleger Archives 25 Fri 03 November 2006 09:01
