Old Mon 12 October 2009, 21:08
weldnh20
Just call me: Dan
Othello
Welding Table Legs - Othello, USA
Copied from elsewhere:
I started my build last weekend, this will be a monster when it's complete. I got most the electrical figured out except the transformer.Looking at pictures and all the different drawings it would be nice just to get a part number and supplier and be done.
Dan
Old Mon 12 October 2009, 21:16
Dan,
The transformer choice depends on which Stepper Motors you are using.
I used the Antek transformer and built my own power supply because I needed two voltages(two different Stepper Motors).
If you are going with a pre-built power supply(not building your own), just tell us what Stepper Motors you are using, and we can give you some suggestions for part numbers.
Old Tue 13 October 2009, 19:59
weldnh20
Just call me: Dan
Othello
John,
Did you use different size motors for the Z & Y . I was looking at th Oriental motor # PK296A2A as recommended
Old Tue 13 October 2009, 20:02
weldnh20
Just call me: Dan
Othello
I got the v groove bearings today,and went over the plasma cut parts with a friend of mine.This weekend lots of stuff should come together
Old Tue 13 October 2009, 20:51
Dan,
I used 3 USED OM motors, 1A1 with 3.6 gears. I used one NEW PK296A2A-SG7.2. I put the PK296A2A-SG7.2 on the Y-Car. The others for the rest.
Your selection of PK296A2A motors is an excellent one and this is what I would have used had I not got the chance to buy 3 USED OM motors, cheap. Many MechMate builders have used the PK296A2A-SG7.2 motors very successfully.
Have you looked at the Antek product offerings? I found them to be very helpful and the products good.
They even provided suggestions on a schematic for a dual voltage power supply design.
Old Tue 13 October 2009, 21:44
weldnh20
Just call me: Dan
Othello
John,
Why is it necessary to cut the angle iron down, I purchased 3x2 angle and couldn't figure out why cut. if the z moves up and down whats it matter.
FAQ candidate
Old Tue 13 October 2009, 21:50
weldnh20
Just call me: Dan
Othello
Haven't looked at power supplies and transformers again. I'm excited about putting all the parts together and pushing it around. I need to study and research motors, transformers,and software a bit before I go blow 2k
Old Wed 14 October 2009, 01:29
If the tracks are not cut down to the specified height, the motors will not swing low enough to reach the racks. To make that work you would have to change at least 7 other components to suit the higher track. Higher tracks would also possibly allow more movement/flexing. Trust us there is a reason for everything being as it is...
Old Wed 14 October 2009, 08:07
Dan,
Okay, Alan answered the question about cutting down the rails while I was sleeping. Thanks Alan.
And regarding...
Originally Posted by weldnh20 View Post
... I need to study and research motors, transformers,and software a bit before I go blow 2k
EXACTLY! And also, when you assemble the Control Box and start testing, you will know exactly how it is all supposed to work. If there are problems, you will be in a much better position to troubleshoot them.
Old Wed 14 October 2009, 18:44
weldnh20
Just call me: Dan
Othello
Thanks guys, I understand. I'm going to try and use my plasma to cut the angle down. Then make a grinding jig. I was wondering how come everyone uses hard stone for grinding instead of a flap disk. Flap disks cut faster and smoother
Old Wed 14 October 2009, 20:23
Someone here tried to have the rails cut down with plasma and just ended up with useless warped rails.
Old Wed 14 October 2009, 20:45
weldnh20
Just call me: Dan
Othello
Heath,
I'm surprised, I'll try on a piece of scrap first and see. Otherwise I will just use a cut off wheel.
Old Thu 15 October 2009, 11:34
jehayes
Just call me: Joe #53
Whidbey Island, Washington
Plasma Vs. Cut-off wheel
I used the cut-off and the angled skate for the 45 degree cuts and had no problem with either. The cut-off wheel went very quickly and was very accurate (assuming you have a solid, flat base on which to place the sled) and the angle grinding went well once I figured out the need to have the leading edge of the grinding wheel as the contact point. BTW - I angle ground my Z-plate this weekend using the same system - no problems. Hope this helps
Joe
Old Thu 15 October 2009, 21:23
weldnh20
Just call me: Dan
Othello
Thanks for the help guy's. I'm amazed at how much information is available on this site. I took a 3 day weekend to start putting together all the money I spent. Have to keep telling my wife it's not a toy. Don't think she's convinced. Over the years it's getting harder to convince her.
Dan
Old Thu 15 October 2009, 21:45
Hen….lucky you, you still able to convince her a bit..... nooooot here
Old Thu 15 October 2009, 23:28
When you start producing things for her, it all falls into place...so just wait until you are making dust.
Old Fri 16 October 2009, 20:41
weldnh20
Just call me: Dan
Othello
Started welding today. Made first mistake of many to come, Cut the frame out jigged it all then started tacking together. Brainstorm,wondered if a 4x10 sheet of plywood available. Well 50 mile trip to town later and it's a problem to get, Cut the tacks off now it will be cut area of 4x8. I'm sure it's overbuilt but I had some off the material left over from a job. X rails are 3X8x3/16 square tube.
Old Sat 17 October 2009, 17:55
weldnh20
Just call me: Dan
Othello
Started welding the legs in place today, should be able to flip it over on sunday. While doing some touch grinding I realized that a hard stone will be better to grind the rails. A flap disk will flex a bit and may cause an uneven surface. I was wondering, people talk about gluing the spoil board to the base board. When the spoil board needs to be replaced how do you remove it?
Old Sat 17 October 2009, 21:38
The spoil board wears away with time. When it gets grubby, you take a light cut over the whole surface (called "re-surface" or "surfacing") and so it gets even thinner. When you get near to the old glue line, you re-surface and glue the next one on top.
(FAQ candidate)
Old Sun 18 October 2009, 15:34
weldnh20
Just call me: Dan
Othello
Legs are on, so far everything is holding square
Old Tue 20 October 2009, 17:09
jehayes
Re: the Spoilboard - Has anyone tried using the same double sided tape used for the racks to hold down the base board onto the cross rails? Would this work? (Assuming the cross rails are welded for stiffness rather than bolted) Just a thought
Old Wed 21 October 2009, 00:00
I think it will work well if you can get a good bond between the tape and the board.
Old Sun 25 October 2009, 16:42
weldnh20
Just call me: Dan
Othello
The table construction is complete. Just waiting for the formed parts then will start on the gantry Y car. I want to order the PC this month. Does anyone have any recommendations?
Old Sun 25 October 2009, 19:13
I bought a used Small Form Factor PC from these guys.
It came with XP Pro and was ready to run. In addition to the price of the machine I paid shipping and taxes (they are located in Texas) for a total of $114. It arrived a couple of days after I placed the order.
The computer is shown in this post from my build thread.
Making Mirrors and Dust Collectors #65 - Pensacola, FL fredjr MechMates already cutting 152 Sun 18 December 2011 09:42
Legs - their purpose and sizing (Can legs be bolted......?) Gerald D 10. Base Table 0 Tue 21 April 2009 00:50
Wood support table #21 - Bellingham, WA - USA jeffh MechMates already cutting 28 Thu 19 February 2009 16:34
Adjustable and/or isolating feet under table legs? Robert M 10. Base Table 9 Fri 21 November 2008 19:46
Table legs for storing sheets underneath vadeem 10. Base Table 2 Fri 01 December 2006 01:26
