Old Tue 17 May 2011, 11:17
sierra347
Just call me: Armando #110
Montgomery, IL
X Rail I beam thickness??
Have been looking for cheap c channel or I beams and have come empty handed on the c channel but there are plenty of cheap I beams around. My question is regarding the thickness of the web, is 1/4 inch thick too thin on a 8" beam? there are also 12" beams with the 1/4 web. Would the 1/4 web 12" work although I would have to deal with raising the cutting surface.
Old Tue 17 May 2011, 19:26
Mando.
The C channel specified for the machine can be either C 8" x 11.5#/Ft or higher which has a modulus of 8.14 in the x-x plane.
The W or S shape "I beam" of that height and equal weight does have a section modulus in the x and y that meet or exceed that requirement. For example a W12x16# has a modulus of 14.9.
This is only one part of the criterea where bending moment, shear and 1/360 span formula's apply...but in the spirit of the Mechmate, your "found" steel sections will be fine.
If any of the qualified engineers in the room disagree....please advise. I only play an engineer on TV!
Best,
SEan
Longitudinal beam options for 350mm Z-axis Red_boards 10. Base Table 8 Mon 22 November 2010 07:38
Problem with Main Longitudinal Beam gixi 10. Base Table 32 Thu 19 November 2009 15:23
AutoScaled Projects - choosing cutters, mat. thickness, etc. servant74 Miscellaneous / General / Whatever / Catchall 14 Wed 28 January 2009 08:14
Laser cut mounting plates thickness James Webster Archives 21 Sun 28 October 2007 09:00
Metric vs. Imperial plate thickness domino11 Profiled (laser cut) & bent steel plate 8 Thu 04 October 2007 21:49
