Go Back   MechMate CNC Router Forum > Common Assemblies & Parts > Profiled (laser cut) & bent steel plate
Old Tue 03 November 2009, 12:16
esadaddy
Just call me: LLoyd
Atlanta(Ga)
Profile cutting with cnc mill?
I was wondering have anyone discussed the possibilty of using a cnc milling machine to cut the profiles? I was wondering why I hadnt seen any post regarding using cnc mills to cut them. I am sure it will require a lot of additional holdown methods but I believe if the parts of similar thickness are nested correctly it should work. Correct?
Old Tue 03 November 2009, 13:17
Of course you can mill the parts, but that would be a lot more expensive than laser cutting........unless your milling is for free!
Old Tue 03 November 2009, 22:09
esadaddy
Just call me: LLoyd
Atlanta(Ga)
Yes, I will be milling them myself.
Old Tue 03 November 2009, 23:37
For milling, I would not nest them on sheets.
I would cut blanks and stack them up to mill 2 or 3 at a time where possible.
Old Wed 04 November 2009, 02:56
esadaddy
Just call me: LLoyd
Atlanta(Ga)
yes good idea. This will also maintain rigidity will cutting. I will just have to hand work the small corners with a set og good needle files.
Old Mon 01 September 2014, 10:13
IMMark
Just call me: Mark #119
Columbus Ohio
Don't forget that with the laser cut kits, the parts are bent as well.
Mark
Old Sat 27 September 2014, 20:23
wetong
Just call me: Yijing A4-407
Dongpo road, dongping
China
Send a message via Skype™ to wetong
CNC sandline cutting machine delongcnc Archives 7 Sat 31 October 2009 15:32
AC motor & VFD used with Mach3 in large CNC stone cutting system osman100 70. Control Systems 39 Sun 17 May 2009 10:16
Help me to choose a foam cutting CNC machine! kotys2 The Market Place 3 Wed 03 September 2008 18:33
How many laser profile cut components required per part number? fabrica Profiled (laser cut) & bent steel plate 29 Mon 07 January 2008 13:32
Grinding V-profile on rail edges Gerald_D Archives 65 Fri 24 November 2006 11:07
