Old Thu 03 July 2008, 05:13
LIBBIT
Just call me: John
Mt Roskill, Auckland
New Zealand
Starting - Christchurch, Rolleston, New Zealand
Hi guys, I’m John from Richards Bay, South Africa, my collogue Johan van der Walt introduced me to MechMate. Wow, Awesome, Fantastic and I’m humbled by Gerald’s openness.
I’m about to emigrate to New Zealand in the next few months and want to build myself a BB there. Are there any BB’s in New Zealand, Christchurch area?
Libbit
Old Sat 14 February 2009, 17:37
LIBBIT
Just call me: John
New Zealand
The design is done...now the build starts
Hi,
Pls see my design as pre G's drawings. Any comments??
John
Old Sat 14 February 2009, 19:28
John,
Interesting design and good luck with your build. When are you moving?
Old Sun 15 February 2009, 00:44
LIBBIT
Just call me: John
New Zealand
Nils,
Thank you.
We arraived in Christchurch, New Zealand October last year. This year is set aside to build a Big Blue MechMate. I've done a 3M model in SolidWorks from G's design. Currently i'm busy getting prices for the motors, bearings, gear racks, etcetera. As i've said before it is damm expencive. Dual Vee bearings from Nick is about NZ$650, I've had prices localy at NZ$ 2500 and NZ$5500.....
You will notice I've changed the legs because i got hold some 50x50x2 square tube, other than that i will use G's design.
John
Old Sun 15 February 2009, 04:08
John,
I did see that you changed the legs. Good luck with your build.
I have a friend that lives in New Zealand, it is a very beautiful country, and I would enjoy the opportunity to see it but you are soooooo far away. Maybe it will happen.
It is hard to change a design that works so well.
Old Sun 15 February 2009, 06:53
John why not weld the short pieces together end to end to make them longer, then build conventional?
Old Sun 15 February 2009, 22:24
Lex
Just call me: Johan #56
Empangeni KwaZuluNatal
Go for it John!
Old Sat 16 May 2009, 02:25
LIBBIT
Just call me: John
New Zealand
Kitchen Table Project started........
Hi guys,
I'm starting my kitchen table project. Pls see attached pic's of panel back plate and wiring diagram. Pls, pls take a look and any comments r welcome.
John
Old Mon 25 May 2009, 02:36
Lex
It is looking good!
I see that you will be using 24v contactors.
Old Sat 17 April 2010, 18:50
LIBBIT
Just call me: John
New Zealand
Most of the wiring done - Auckland, New Zealand
Hi, the progress is slow due to, as u could guess, money.
Anyway pls see photo of completed panel (cant seen to upload a pic). Now I'm waiting on the Gecko's and motors to complete kitchen table build. I have used a 230v contactor and will allow the BOB via 24v relays to pull in the router and vacuum motors. I will start with a router and later move to a VSD.
Question to the Forum....can I use old copier stepper motors as test pieces? If so, what do I look out for?
Next job is Ubuntu with EMC2......
Tks to Johan (Lex) for his wiring diagram and help from a friend.
Regards, John
Old Sun 18 April 2010, 04:36
Welcome back. Glad you are making some progress !!!
Old Sun 18 April 2010, 05:19
Hi John, glad to see perservere members around Thumbs up!!!
I would prefer to keep the parallel port cable away from the transformers. Even if the parallel port is shielded. It carries the raw signal from your PC & it is the weakest signal in the whole machine system.
Using copier stepper motors may work, but without any spec of the motor, I couldn't tell...
Old Sun 18 April 2010, 13:49
LIBBIT
Just call me: John
New Zealand
Hi guys,
Thank you Ken and Mike.
Ken your advice makes sence, tks. What I've done is I've got the left side of the panel is the 230vac transformer lines and the right side mainly the DC lines.
CU
Old Wed 09 June 2010, 14:10
LIBBIT
Just call me: John
New Zealand
Hi Guys,
I have an option to get 6 x 201 Gecko drives here in New Zealand for $500 NZ (about $350 US) and was wondering if the 201 drive is suited for the MechMate? I'm going to use 4 X Motion King stepper motors 34HS9801. Tks.
Old Wed 09 June 2010, 14:28
The 201's will work. Your concern with the 34HS9801 is your voltage and the 201 will beable to drive that voltage and I believe other people have used them on there MM successfully, search the forum to be sure...
Old Wed 09 June 2010, 20:40
Our first machine was with G201's and they are still going strong. In fact, we have since killed 202's and 203's but not a 201 yet. It was recommended practice to put a capacitor directly onto each of the early version G201's.
