#1
Finally getting to the planning stage.
Hello everyone, my name is David and I am based in Suffolk in the UK. I have lurked around this forum for many years on and off. I printed the plans out some years back and the file has been sitting gathering dust through two house moves and the birth of two of my children. I have however finally raised enough support from my financial controller (the wife) to start planning a build.
My background is mainly IT infrastructure management over the last 25 years but I originally trained in engineering and worked with CNC lathes and Mills for a while. I also spent some time as a draughtsman using Autocad 9 - 12. These days I still use Draftsight for small projects due to the similarity with Acad commands. My intention is to build a fairly standard 8' x 4' machine and I have started budgeting for bits. I realise most people on here use Mach but I am going to give linuxcnc a go if I can make it all work reliably. I am also considering using a Mesa 7I76E if I can find some real world implementation cases. If anyone has any good sources for parts in the UK I would be more than happy to hear. Regards David |
#2
Planning is the key and preparation is the lock, think of the forum as foresight and you will have a machine running with the best of them. Get in a hurry (like I did)and you will be making upgrades after. Welcome and enjoy your build.
#3
Welcome David. I have a similar background, IT Management with early hands on stuff. Since I was familiar with electronics, I started with the Control Box. Once I got the motors turning, I moved on to the cutting, welding, grinding, tapping stuff.
Good luck with your build. We appreciate "watching" builds via photos and please ask questions when you need help. We don't mind helping. Actually, we enjoy seeing "yet another" build. |
#4
Welcome. Best of luck with your build.
#5
Welcome !!!
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Finally Back At The MM! - Los Angeles, CA | st_indigo | Introduce yourself and start planning | 7 | Tue 30 April 2013 06:19 |
....my first start..finally | saas | Construction started, but not cutting yet | 1 | Mon 11 March 2013 22:07 |
Finally bought the plans | nsfr1206 | Introduce yourself and start planning | 36 | Mon 28 January 2013 16:09 |
Finally completed upgrading #80 - Burlington, NC | toad | MechMates already cutting | 34 | Wed 12 October 2011 11:35 |
Drakkn Custom Shop Stage 1 CNC Research | drakkn | Introduce yourself and start planning | 3 | Tue 05 October 2010 15:03 |
