Old Tue 30 July 2013, 17:21
Mrayhursh
Just call me: Hurshy
Riverview, Florida
Smooth Stepper Preferances
I have read the postings concerning smooth steppers. I would like to know which one works best with the PMDX-126 BOB. I asked PMDX and they recommended Soigeneris. Any advice?
http://www.soigeneris.com/ethernet_s...r-details.aspx
http://www.soigeneris.com/smoothstepper-details.aspx
Old Sun 04 August 2013, 15:15
No matter who sells them, there is only one Smoothstepper but two types.
Ethernet, the newer one is a preferred option
Old Thu 08 August 2013, 22:43
Mrayhursh
Riverview, Florida
Smooth Stepper
I purchased the smooth stepper from Soingeneris for $180. It was the best price I found. The device requires 2 jumper cables. Since I have the PMDX-126 BOB. I chose to go with the 2 LPH26 to LPH26 cables at $2.50 each.
The board piggybacks the PMDX board. You will need to cut 3 stand offs. If you choose to make your stand off post out of metal you will need to change the JP1 (closest to the power connection). also, the board requires a 5VDC power supply.
If you need one they sell the MeanWell unit. After downloading all the differ documentation that the various companies have for this one board. I found out that MeanWell also provides a DIN version that is available from Jameco Electronics for 14.95. It is probably worth it just to keep the wiring clean.
Smooth stepper paul60 70. Control Systems 14 Tue 30 December 2014 16:25
Closed Loop Stepper Compared with Open Loop Stepper Leadshine-Eric The Market Place 10 Thu 14 June 2012 05:15
