Old Wed 13 February 2013, 14:04
zumergido
Just call me: Fernando
BS AS
melamine particle board. 6mm 2 flute
hi people
iam doing some cuts on melamine 18mm made of particles
cant find the right feed and/or speed.
i use SGS brand 6mm 90113 bits, its a two flute upcut and the downcut match.
iam getting a little of burn on the bit. its getting black on the time.
whats the optimal and fastest way to cut?
i have a 3hp 18000rpm spindle and set the machine to move at 4600cm/min has normal operation.
i found this calculator now http://zero-divide.net/index.php?page=fswizard
will update on the test.
Old Wed 13 February 2013, 14:07
zumergido
BS AS
have made this calculation
http://zero-divide.net/index.php?pag..._tool_id=98309
will update how its going
Old Sun 17 February 2013, 19:15
ger21
Just call me: Ger
Detroit, MI
Do you mean 4600mm/min? If so, that's much too slow. Try 8000-12000mm/min at 18,000 rpm.
raw Particle board cutting danilom Cutting various materials - bit selection, feeds, speeds 3 Tue 19 June 2012 02:23
What to use to cut Melamine Board? Daya Cutting various materials - bit selection, feeds, speeds 17 Tue 13 March 2012 22:08
Straight-flute bits and safety lumberjack_jeff Cutting various materials - bit selection, feeds, speeds 8 Sat 27 March 2010 13:20
What is the purpose of a spoil board or bleeder board? j_wizard 10. Base Table 1 Sun 09 August 2009 17:00
Sizing Melamine Panels hflwaterski Archives 8 Sat 21 June 2008 06:11
