Closed Thread
Old Sat 21 April 2012, 11:38
Metalsmith
Just call me: Metalsmith
Jacksonville, Fl
Need to talk to motor guru about an OT project....
I am looking for a small motor with good torque to power a hand held small belt sander.. I am thinking 4" x 8" long x 3 " wide Motor will set between 2 rollers front and aft, with a cogged belt drive along one side, with a sheet metal coverfor belt. Are there any motors that are 3" w x 3"square ???I have a hand drawn layout done ... Will 1/4" aluminum and will try to get some of the Florida guys to maybe cut out the proto -type plates ... Right now motor is holding me up ....am looking at a small marine pump motor ...
  #2
Old Sun 22 April 2012, 06:07
They don't sell motor by the inches...
Torque is a relative quantity &"Good torque" meant nothing when no reference is established...
A simple question can sprawl into a whole academic principle if you want to do it correctly.
You gotta find out what Torque, rpm & operating voltage... & type of electricity you are going to use. i.e. 110V, 230VAC single phase or 240V,415V,600V 3 phase or even DC...
one of the very basic formula for determining what you need is as follows:-
Power (watt)= Torque (in N.m) x 44*RPM/420 (in rad/sec)
(I don't work with imperial when it comes to power, learning in metrics is enough hassle & I wouldn't wish to remember another set of numbers & formulas in imperial)
After this, don't forget to ask yourself if you prefer to direct drive or geared or gearbox, or electrical gearing... etc etc... & factor in the efficiency.
  #3
Old Sun 22 April 2012, 14:46
Metalsmith
Jacksonville, Fl
I am dyslexsic in math, but have great 3-D perspective.... I can build things by sight....I know how I want it to look, in my head. My problem is showing everyone else !
I need a motor that is between 76.24 - 88 mm ( 3- 3.5 " ), ac-115v, 60 hz, single phase, 1500 rpm with a square body or mounting flange.
I can convert to metric if I have to , but don't want it shoved down my throat....a cheap HF digital calipher settles that problem.
I did say it would have a simple cogged belt drive...change pulleys for rpm change
The rollers will have a slight crown the keep the belt centered and spray rubberized coating.....The rollers will be held in with ground hex-head shoulder bolts and and a small roller will be used in between the end rollers to adjust belts
I know there are mini- belt sanders out there but I refuse to play $300-500 us for a piece of plastic crap. Will build to size of available belts for Paxxson mini's...
Working on a drawing....by hand...LOL
  #4
Old Sun 22 April 2012, 23:03
Use a power drill.
  #5
Old Sun 22 April 2012, 23:21
Metalsmith
Jacksonville, Fl
This will be used to shape wood on surfboards....if I wanted it gouged, I would use a sharp piece of rock ! never mind, I will google ..." Small ac electric motor"...
Closed Thread
Talk to Al of BobCAD CAM aldepoalo The Market Place 67 Fri 19 September 2014 16:01
Project? n-ghadimi Introduce yourself and start planning 1 Tue 03 November 2009 05:03
Some IC's needed for another project Gerald D Miscellaneous / General / Whatever / Catchall 11 Wed 23 September 2009 12:26
Project MechMate, Denmark (Fyn) psyklopz Construction started, but not cutting yet 8 Mon 02 February 2009 22:25
