Old Sat 24 March 2012, 19:40
wolfy15
Just call me: Ghis
Québec
Smile Start planning for 2 MM
Hi!
I plan to built 2 MM
one will be 4' by 8' and one 5' by 10'
the 4 by 8 will be for different job and the 5 by 10 will be for cabinet job
I start my BOM and one question first, I plan to use the motor PK296A2A-SG7.2
for both MM I read a lot on motor but I'm not confident it is the best motor for the job I want to make whit both MM.
If I use this motor I will use power supply PMDX-135 whit a transformer AN-6438
its 38V 600VA What do you think about that.
Wolfy
Ghislain
Old Sun 25 March 2012, 14:48
wolfy15
Just call me: Ghis
Québec
After reading more and more
I will go whit 640 oz motor and belt drive 3/1 or 4/1
I need to find the best way to do it
Ghislain
Old Wed 18 April 2012, 16:20
wolfy15
Just call me: Ghis
Québec
Thumbs up parts are comming
I order a lot of part from Mike
Wait to receive the parts
The 2 base table are almost done.
I can't wait to receive part from Mike
Ghislain
Old Wed 18 April 2012, 16:43
Two at once?
Sounds fun.
Old Thu 19 April 2012, 02:15
Axel1966
Just call me: Axel
Paris
France
Great !
I appreciate you have your reasons to build 2 different size MM.
Through, the difference of size may not induce a significant cost difference.
With two 5'x10', you'll be able to make serial jobs with more efficiency,
un/loading #1 when #2 is cutting, all done with a single hand.
What you want to do on the 4'x8' will be done as fine on a 5'x10'.
With same dimensions, you may build faster,
and maybe get a better price for some parts.
It's just an open question - as far as I'm concerned.
Otherhand, you may not have enough room for two 5'x10'.
Regards.
Old Thu 19 April 2012, 08:13
Might be a little late to convince him
Old Thu 19 April 2012, 09:04
bolingerbe
Just call me: Bryan #54
Clinton(Tennessee)
Ghis,
One thing I would suggest would be assembling the Machine one at a time. As I only constructed on machine, a lot of lessons were learned along the way that could allow a much easier assembly of your 2nd machine. I do understand doing the fabrication “Cutting and welding the base table, gantry, y car etc.” work for both machines at the same time, but believe the assembly and electronics would go smoother one at a time. This is just what my experience has led me to believe. But no matter how you proceed I look forward to seeing you build and wish you good luck.
Old Thu 19 April 2012, 11:44
wolfy15
Just call me: Ghis
Québec
planning
thank for your comments
Why 2 Table I don't have enough place in my shop for a 5 by 10
the 5 by 10 will be in the cabinet maker shop whit my friend and the 4 by 8 will be in my shop at home and it will be for a lot of different job.
for building process its a friend ho weld the base table.
after that I will finish to built one table before to start the second one.
I plan to built the electronic part on a kitchen table before mounting on machine.
its not my first machine built i already built 2 Joe's cnc the last one is a
cast cnc Rack & pinion I learn a lot during the building process and I still have a lot to learn.
thank
Ghislain
Old Thu 19 April 2012, 17:15
Axel1966
Just call me: Axel
Paris
France
Sorry, I think I get all wrong.
Old Sun 22 April 2012, 12:16
normand blais
Just call me: Normand
montreal
Hé Gyslain avec 2 machine tu va etre pret a batir un stade
Old Sun 22 April 2012, 19:21
wolfy15
Just call me: Ghis
Québec
Stade de Québec
Salut Normand
Je devrais peut-être proposser mes services a la ville.
sa irrais peut-être plus vite.
Ghislain
Old Mon 23 April 2012, 07:41
normand blais
montreal
Té mieu de patiner , il y aussi la colusion ou ben ils ont arreté ça la semaine passé? En tout cas tu aura une machine a la couleur de votre équipe
Start of construction in Russia. Maxim77 Construction started, but not cutting yet 3 Tue 04 October 2011 09:29
New Start -Macclenny, FL mlscott52 Introduce yourself and start planning 4 Thu 04 August 2011 06:05
Planning to Start In PA technoid Introduce yourself and start planning 1 Fri 22 April 2011 05:25
Fire, how easy it is to start one! smreish 55. Dust Management 8 Sun 10 October 2010 20:22
Where to start, no really! ChiknNutz General - MM Build 6 Mon 15 December 2008 20:06
