Old Fri 06 May 2011, 05:22
giggler
Just call me: giggler
na
Motor plate pivot play?
Hi,
My motor plate pivot holes for the x axis are drilled to 10mm (both plates, motor and fixed axis). They actually measure 10.1mm using a caliper but the bolt unthreaded shank is like 9.9mm so there is a little play. My M8 restraint bolt slots are slightly larger so they wouldn't interfere during rotational movement with spring pressure and rack height variances. I've not done the pivot bolt up with the teflon washers and restraint bolts yet but is this something that will cause a problem with backlash from your experience?
The last thing I want is the motor to reverse direction and instead of moving the axis it moves around the pivot point for small step changes.
dc
Z Zero Plate Rad Racer General - MM Operating 2 Wed 04 January 2012 07:45
MetalHead Metal Motor Plate Setup MetalHead Motors & their mountings 20 Wed 09 November 2011 06:23
Z Home/Limit with ATO Plate.... salewis 70. Control Systems 9 Mon 08 November 2010 16:53
True Torque of a Servo motor for comparison to a Stepper motor, when used in a router Mcyoda Motors & their mountings 3 Tue 19 August 2008 00:50
